Author: Subject: another stupid sva mirrors question
ned
posted on 12/5/05 at 01:10 PM Reply With Quote
having read the draft sva manual, i don't understand part of the definition:
d. in the case of a four wheeled vehicle obligatory
mirror only, a reflecting surface area sufficient
to accommodate a rectangle,
• in the case of an interior mirror 40mm high x
80mm length
• in the case of an exterior mirror 40mm high
x 70mm length and a line parallel to the
height of the rectangle not less than 70mm
in length.
what does the 'line parallel to the height of the rectangle not less than 70mm' bit mean?
thanks,
Ned.
beware, I've got yellow skin
posted on 12/5/05 at 01:29 PM Reply With Quote
I read this as "a rectangle 70mm wide and 40mm high will fit on the mirror bit". I made a rectangle out of card and tried it on my external mirrors - fitted easily.
This may well be a misunderstanding, but my mirrors were well over the size of the bit of card so I didn't take it any further.
barrie sharp
Hi Ned i'll try to explain if you have a mirror that is 40mmx70mm along the height of it it must be at least 70mm high
let me try again if you have an oval or tear drop shape mirror it must have at least a 40mmx70mm area BUT must be at least 70mm high at its highest bit
(i must learn how to do digrams)
i know all this because i fail on this and had a heated discussion about it with the tester.
hope it makes sense
barrie
[Edited on 12/5/05 by barrie sharp]
the cars looking good" a blind man would be pleased to see it"
''stop press'' the blind mans seen it said "it felt ok"
posted on 12/5/05 at 01:49 PM Reply With Quote
Oops! I'd forgot the "it's got to be 70mm high somewhere in the width of the rectangle" bit.
It's amazing how the SVA headaches fall away once you're a few months after passing...
Donners90
posted on 12/5/05 at 02:24 PM Reply With Quote
Summink like this
barrie sharp
posted on 12/5/05 at 02:51 PM Reply With Quote
Donners thats just what i said
diagrams are always better.
barrie
ned
posted on 12/5/05 at 02:56 PM Reply With Quote
dos the 70mm height have to be continuous glass? or could youget a rectangular mirror and tilt it upwards? (ie i want to use an spa mirror)
Ned.
barrie sharp
posted on 12/5/05 at 03:24 PM Reply With Quote
I think your moving the goalposts ned (the test man will only refer to the book)
imo stick the biggest mirrors you can and then change after sva (I did)
after my fail i put on some mirrors from a trials motorbike on (see photos at sva http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=oscar%20006.jpg) then changed back i still see enough out of the small ones.
barrie
ned
posted on 12/5/05 at 03:27 PM Reply With Quote
what a nuisance. thanks for the replies...
tks
posted on 12/5/05 at 09:08 PM Reply With Quote
uhhh
i was just wondering..
how difficult is it to mount the mirrors?
where do you need to look at?
would be mad to drill 2cm wrong??
TKS
p.s. on wich page is this SVA rule stated on the draft version..??
ned
posted on 13/5/05 at 08:30 AM Reply With Quote
page 99 of the pdf on hellfire's website
