Jenko
posted on 1/11/07 at 12:21 PM |
Fuel systems - pipe diameter..
Just about to embark on a Megasquirt / Bike TB conversion on my Westfield (2ltr CVH).
There seems to be some confusion about diameters for the fuel pipesfor the high pressure side......
WHat is the general consensus on tis...SBD have a nice diagram that says 12mm, but why so large?.....what is the standard fuel rail?......any other
info on this would be useful....
Ta......Paul.
posted on 1/11/07 at 12:51 PM |
Ø8mm should be ample - production car FI fuel lines are no bigger than that.
lsdweb
posted on 1/11/07 at 01:18 PM |
Paul
What's the size of the fuel rail onthe TB's - that's your determining factor I'd guess.
Wyn
Jenko
posted on 1/11/07 at 02:06 PM |
Am yet to receive the TB's, but that's a good point...I will check..
Agree that 8mm should be fine - I'm thinking the SBD set up is used to dealing with 250bhp plus vx engines, and would be over kill on my
engine....Can't believe the GSXR600 fuel rail would be that wide.
stuart_g
posted on 1/11/07 at 02:43 PM |
8-10mm ID will be more than enough.
mojojeff
posted on 4/12/07 at 10:58 PM |
fuel pipe size
i'm building two MK's one 2 ltr zetec on throttle bodies and one using Honda ST1100 V4 pan euro.
Is it necesarry to use 8mm feed and 8mm return fuel pipe? or will 6mm return be ok?
martyn_16v
posted on 4/12/07 at 11:12 PM |
Most people (me included) use 8mm OD pipe. You'll find the same on most OEM's as well. The outlets from most fuel pumps (and the tails on
fuel filters) are generally 8mm.
