Metro slave cylinder again
LBMEFM - 18/7/17 at 08:44 PM
Following on from my recent posting re Metro 1.3cc clutch slave cylinder luckily one of our members has got one for me. However, I also need the bracket and the lever. Looking on the web I see that there are two types, standard and verto are they interchangable or if not any ideas what the difference is?
Shooter63 - 18/7/17 at 09:53 PM
Presuming we are talking about a metro with an A series engine, a verto type clutch has the slave cylinder mounted on the wok ( clutch cover) with a short actuating arm, the earlier non verto clutch has the slave cylinder mounted on the drop gear housing with a long actuating arm. If you have a verto clutch you cannot just change the arm and bracket to non verto you have to change the flywheel/pressure plate and back plate and vice versa.
Shooter
redscamp - 18/7/17 at 11:14 PM
A series metro, early hydraulic long arm
late (verto) cable operated.
main short/long arm slave cylinder diffrence return spring and tab mounted on long arm
redscamp - 19/7/17 at 12:03 AM
verto short arm with custom slave mounting bracket (note adjustable push rod and redundent stop bolt).
i dont see why a long arm would not operate a verto cluch with an adjustable push rod (or the old trick of heating and bending the arm) i intend to fit one at some point.
http://s1252.photobucket.com/user/redscamp/media/DSCF1609.jpg.html
LBMEFM - 19/7/17 at 06:32 AM
Thanks for your help, all is now clear. If you want to know something ask a Locost member.
minitici - 19/7/17 at 12:49 PM
I've got an A+ verto short arm and slave mounting bracket if you need one.
Verto slave bracket & lever
LBMEFM - 19/7/17 at 03:25 PM
Thanks minitici u2u sent.
