New Topic New Reply
Author: Subject: Steering improvements 2
panichat
posted on 26/3/11 at 11:28 AM Reply With Quote
Hi all
In the thread further down the page we have been discussing how to get fantastic steering (because quite a few people are struggling to get beyond the "IVA pass but not good enough" stage.
People have contributed lots of great ideas but we still haven't got a definitive measurement of exactly where the upper and lower ball joints should be in relation to each other.
Would any clever/confident people like to put forward their opinion for length A and/or angle B
Castor diagram
Castor diagram
Dave
mad4x4
posted on 26/3/11 at 11:33 AM Reply With Quote
if we know A we can calc Angle B
Scot's do it better in Kilts.
Confused but excited.
posted on 26/3/11 at 12:34 PM Reply With Quote
Surely you define angle A as required and then calculate dimension B to suit the wishbone vertical spacing.
hicost
posted on 26/3/11 at 12:52 PM Reply With Quote
How to
I have just gone through this exercise and purchased the following two pieces of equipment
Tried lots of ways before but these enabled me to get the castor I wanted. I cut all the suspension off the front of the car and welded on new brackets to suit.
"I cant do that without accidentally grabbing hold of the work of the divine potter"
panichat
posted on 26/3/11 at 01:52 PM Reply With Quote
HiCost - I'm full of questions - What are those? Where did you get them? Were they expensive? What castor angle gave you the best result?
Dave
mad4x4
posted on 26/3/11 at 02:14 PM Reply With Quote
Any one got a set of MK Indy wozsher arems that they can measure. this should give us a ball park?
prelude1980
posted on 26/3/11 at 03:27 PM Reply With Quote
I did mine with an angle of 7-8 degrees, my self centering seems fine
Speed has never killed anyone. Suddenly becoming stationary... that's what
gets you.
https://www.topcashback.co.uk/ref/dodd1980
Bare
posted on 26/3/11 at 04:42 PM Reply With Quote
Castor is curious.
On a Lotus Elan and Europa it is set at 3 degrees. On a lotus Seven it is at 5 degrees.
A series 4 Seven I believe(?) is at 3 degrees
ALL of the above cars have 'proven' to handle erm..better than most.
Possibly there are other bindings (?) in the suspension / steering setup that causes self centering to be poor?
panichat
posted on 26/3/11 at 06:01 PM Reply With Quote
Outcome
Ok - it a long time since I did this type of maths so feel free to find errors.
Assuming an angle of 8 degrees is suitable (angle between vertical and line joining the upper and lower ball joints).
Distance between centre of ball joints (hypotenuse) = 210mm (approx)
sin 8 = A/210
A=sin8 x 210 = 0.13917 x 210 = 29.2mm
Therefore an offset of 29mm seems about right.
I am a bit short of that so I need to move the upper brackets back about 9mm.
Please give comments before I get get the angle grinder out!!!!!
Cheers Dave
posted on 9/5/11 at 04:28 PM Reply With Quote
Root problem is lack of (virtual) King Pin Inclination designed into the Ford upright a light car needs more KPI than a heavy car. KPI is the main generator of self-centering and steering stability.
New Topic New Reply
