New Topic New Reply
Author: Subject: winter upgrades update
Stuart_B
posted on 2/5/11 at 03:28 PM Reply With Quote
hi all, well i started my winter upgrades a while ago, but still not finished yet
so i thought it was time to take some pictures and upload them.
this is what it was like, apart from the rear arches had been damaged
bubble screen fitted 3
the 1.6 pinto
the 1.6 pinto
so this winter, it got so far:
quick rack fitted
hi spec rear brakes
wilwood bias valve
windband set up
total rebuild of the pinto, to a nice spec,
new manifold for bike carbs
dizzy non-vav advance this time
Burton cam cover
Westfield alu sump
shiny indicator stalks
carbon rear arches
carbon front arches
still doing the carbon work it will not be perfect but it will do for now until next winter)
i am sure there is more, but that is a brief run down for now.
new rear brakes
new rear brakes
new bike carb manifold
wideband display
wideband display
Lamba sensor
Lamba sensor
shiny pinto
shiny pinto
air filter
air filter
rear arche
rear arche
cheers
stu
omega0684
posted on 2/5/11 at 04:30 PM Reply With Quote
get her on the rollers!
Stuart_B
posted on 2/5/11 at 04:33 PM Reply With Quote
soon but i do not think i will be close to your power, but it will be a step in the right direction
Stuart_B
posted on 16/5/11 at 07:25 PM Reply With Quote
well i have driven her now, just under 100miles, with a few issues, but most off them are sorted, so tonight i thought i will clean her up, and take some pictures:
front of car
front of car
front of car
front of car
rear of car
rear of car
dash
dash
front cycle wing
front cycle wing
rear arch
rear arch
cheers
stu
Stuart_B
posted on 29/5/11 at 06:35 PM Reply With Quote
Originally posted by Stuart_B
new wheels and tyres
the new wheels 17", and tyres(888)
now time to sort out why i had a load of steam and water flying about last night, after a good thrashing
stu
Stuart_B
posted on 5/6/11 at 07:52 PM Reply With Quote
new wishbones, supplied by danny keenan:
mk front wishbones
mk front wishbones
mk front wishbones
mk front wishbones
just need to fit them now.
thanks again danny great work
stu
mad-butcher
posted on 6/6/11 at 06:14 PM Reply With Quote
Couple of questions about wishbones, are they just rosejointed or do they allow you to move the wishbones back 15mm to help self centering and does the Transit drag link joint screw into the wishbone or does it use the alloy adjuster.
[/img]
tony
[Edited on 6/6/11 by mad-butcher]
Stuart_B
posted on 6/6/11 at 07:01 PM Reply With Quote
hi there, it still does have the thread for the Transit drag link at the top.
and yes they do allow the wishbone to move back more, not quite sure what distance yet, as i will be getting Danny to set my car up for me
stu
mad-butcher
posted on 6/6/11 at 07:41 PM Reply With Quote
Shame about them not taking the adjuster as it saves having to take the mushroom out to adjust the camber also allows for fine tuning camber as you're not restricted to one complete turn of the joint.
tony
New Topic New Reply
