New Topic New Reply
Author: Subject: which nuts should i check
graememk
posted on 20/4/07 at 01:02 PM Reply With Quote
ok i'm going to drive to stoneliegh in the indy, it will of only had its number plats a few days, so which nuts should i be checking just incase they work loose?
i guessing the ones that hold the mushrooms in are suspects and the bottom ball joint but what else falls off?
andyace
posted on 20/4/07 at 01:05 PM Reply With Quote
http://tcrc.acor.org/tcexam.html
Mr Whippy
posted on 20/4/07 at 01:07 PM Reply With Quote
why not double up the nuts to lock them?
few are likely to fall off, take it for a big drive and then check. If it was me I'd have done at least 1000 miles on the first day it was on the road (based on the past)
just really tighten up the wheel nuts.
Mr Whippy
posted on 20/4/07 at 01:08 PM Reply With Quote
I just knew someone would...
graememk
posted on 20/4/07 at 01:09 PM Reply With Quote
pmsl
stevec
posted on 20/4/07 at 01:19 PM Reply With Quote
If you have used nuts and bolts and penny washers for the rear arches , check them, they cant fall off if you have used nylocs but they settle and go a bit limp, rather like the previous picture
Also the ones that hold the front calipers to the uprights.
Just do a front to rear spanner check every now and then.
Steve.
[Edited on 20/4/07 by stevec]
PAUL FISHER
posted on 20/4/07 at 01:33 PM Reply With Quote
Rear top wishbone nuts are prone to working loose,even though they have a locking nut,and drive shaft bolts on the disc brake type rear axle.
RazMan
posted on 20/4/07 at 02:01 PM Reply With Quote
During my build I painted a stripe of anti-tamper paint over the suspension nuts and any others that are tightened with a torque wrench. That way you can see at a glance if anything has loosened.
It only takes a few minutes to do the whole car and can save you loads of time if anything drops off
Raz
posted on 20/4/07 at 03:04 PM Reply With Quote
The important non-nylocked ones!!!
Propshaft bolts
Driveshaft bolts (for Lobro type driveshafts)
The important nylocked ones (ie only one mission critical nut/ bolt)
Upper and lower swivel / ball joints
Drive-rod ends
The quite important ones (two bolts holding each bit in place)
Wishbones (upper and lower)
So far I've had 5 driveshaft bolts come undone and 1 ball joint nut come undone....
DarrenW
posted on 20/4/07 at 03:17 PM Reply With Quote
Caliper bolts.
James
posted on 20/4/07 at 03:55 PM Reply With Quote
Engine Bolts!
Happened to notice my timing pulley bolt 'looked funny' the other day.... turns out it was loose to the point I could undo by finger tip.
So started checking the others... The timing belt tensioner bolt was getting loose and the tensioner had slipped.... to the point where turning the head bolt moved the head and belt.... but the crank stayed still!
If Ihadn't noticed I'd have written the engine off shortly!
James
andyace
posted on 20/4/07 at 04:01 PM Reply With Quote
Originally posted by graememk
pmsl
I would be less worried by the lump and more worried that something else appears to be missing
SixedUp
posted on 20/4/07 at 04:03 PM Reply With Quote
Richard
posted on 20/4/07 at 04:07 PM Reply With Quote
It was a bit exciting
Never mind- its the propshaft ones I'm really worried about....
New Topic New Reply
