BEC Airbox designs
reb - 31/1/18 at 11:54 AM
Hi,
I understand that it is hard to match or even exceed the performance of the stock bike airbox.
However I was wondering how much worse the design (made of aluminium) is which you can see on the pictures below?
Such a design would not protrude the hood much and I would be able to fabricate it myself.
Obviously the intake runner length is way longer compared to stock which should result in a loss of horsepower in the upper rpm range but a gain of torque in the lower rpm range.
The airbox from Reverie has the stock runner length but it also costs 600 bucks.
What are your thoughts?
Reverie:
ArthurR - 31/1/18 at 12:24 PM
Andy at AB Performance manufactures a fibreglass airbox for the Honda Fireblade, you may be able to adapt that.
reb - 31/1/18 at 03:41 PM
I know his Airbox but it will probably not clear my engine mounts and furthermore I need an airbox which is compatible with a Gen2 Hayabusa throttle body spacing.
Dougie73 - 31/1/18 at 06:39 PM
Pipercross do a plastic universal airbox with a filter incorporated. Costs about £200. You can fit it with 90 degree silicon hoses and drill out a universal backplate to suit. You should also be able to fit the original rampipes in the box. You'll end up with an intake tract about 150mm long.
cosmick - 9/2/18 at 09:56 AM
Check out my Photo Archive.
DANMAN - 28/4/18 at 11:04 AM
What sort of engine are you using? If it is a later model job with secondary injectors they will need to be allowed for as part of the air box design. I am going through this at the moment with mine with a 2005 CBR1000 engine and trying to keep everything under the bonnet, would also like to see what others have done with theirs.
alex89 - 13/5/18 at 08:48 AM
here's mine
Jambohargs - 14/5/18 at 08:44 PM
Hi, have you done this and does it work? It seems madness that the reverie grp or any other options works out best part of a grand once you've got the duct, filter and scoop too. Really want to sort the induction noise on my gen 2 busa MK but need a cheaper solution
Dougie73 - 15/5/18 at 07:08 PM
U2u sent
