hi guys,
What do you use / tips, to remove valve stem oil seals on a 2.0l silver top Zetec?
Cheers!!!
I pulled a set out a Blacktop yesterday. I used a pair of valve stem pliers made by laser.
https://www.ebay.co.uk/itm/Laser-Tools-6399-Valve-Stem-Oil-Seal-Pliers/272270180161?epid=1152832407&hash=item3f64913f41:g:Mn0AAOSw7j5bBuG6
I had to grind a bit of so I could get them deeper
[Edited on 8/8/20 by big_wasa]
Where did you grind off, the handle bit?
Did they come out easy with the tool?
Many thanks!!!
I can’t upload photos again.
But if you imagine needle nose pliers tapering and getting thicker. You need to take a little of the tapper to get them in deeper.
Very easy, took all 16 out in seconds. Grip and wiggle.
Perfect,
Will order some and give it a go!
Top man as usual!!!
I also bought these when overhauling my zetec to replace the valve seals. They work a treat. Didn`t have to grind anything off mine though.
