Author: Subject: BEC Airbox designs
reb
posted on 31/1/18 at 11:54 AM Reply With Quote
BEC Airbox designs
I understand that it is hard to match or even exceed the performance of the stock bike airbox.
However I was wondering how much worse the design (made of aluminium) is which you can see on the pictures below?
Such a design would not protrude the hood much and I would be able to fabricate it myself.
Obviously the intake runner length is way longer compared to stock which should result in a loss of horsepower in the upper rpm range but a gain of torque in the lower rpm range.
The airbox from Reverie has the stock runner length but it also costs 600 bucks.
What are your thoughts?
Reverie:
ArthurR
posted on 31/1/18 at 12:24 PM Reply With Quote
Andy at AB Performance manufactures a fibreglass airbox for the Honda Fireblade, you may be able to adapt that.
reb
posted on 31/1/18 at 03:41 PM Reply With Quote
I know his Airbox but it will probably not clear my engine mounts and furthermore I need an airbox which is compatible with a Gen2 Hayabusa throttle body spacing.
Dougie73
posted on 31/1/18 at 06:39 PM Reply With Quote
Pipercross do a plastic universal airbox with a filter incorporated. Costs about £200. You can fit it with 90 degree silicon hoses and drill out a universal backplate to suit. You should also be able to fit the original rampipes in the box. You'll end up with an intake tract about 150mm long.
cosmick
posted on 9/2/18 at 09:56 AM Reply With Quote
Check out my Photo Archive.
If it can't be fixed with a hammer then its probably an electrical problem.
DANMAN
posted on 28/4/18 at 11:04 AM Reply With Quote
What sort of engine are you using? If it is a later model job with secondary injectors they will need to be allowed for as part of the air box design. I am going through this at the moment with mine with a 2005 CBR1000 engine and trying to keep everything under the bonnet, would also like to see what others have done with theirs.
Daily Driver - Audi A4 2L Turbo Quattro
Work Horse - Falcon XR8 Ute - Now Supercharged!
Rally Beast - 1972 Ford Escort 2L
Off The Road - Locost 2L Turbo (Z1 Concept)
Track Car - Stuart Taylor Blade
alex89
posted on 13/5/18 at 08:48 AM Reply With Quote
here's mine
Jambohargs
posted on 14/5/18 at 08:44 PM Reply With Quote
Hi, have you done this and does it work? It seems madness that the reverie grp or any other options works out best part of a grand once you've got the duct, filter and scoop too. Really want to sort the induction noise on my gen 2 busa MK but need a cheaper solution
Dougie73
posted on 15/5/18 at 07:08 PM Reply With Quote
U2u sent
