Author: Subject: Fisher fury, Ex RGB, road registered (without bodywork) £3500
ch1ef
posted on 30/7/19 at 02:34 PM Reply With Quote
Fisher fury
Ex RGB race car, but also road registered
It is a high spec car, built and did win races and was a competitive fast car. But also kept simple with simple available parts so it is cheap to run and maintain. For me a perfect middle ground for a good trackday car.
Road registered 2003 Fisher Fury
No MOT
Fireblade engine with aluminium baffled sump (~150hp)
Sequential gearbox allowing for clutchless upshifts.
TTS foam filter
Spax adjustable suspension
Front and rear anti roll bar
Dynojetted carbs undertaken by Honda dealer.
Adjustable brake bias
Fire extinguisher
Luke harnesses
Sparco removable steering wheel
Hi Spec disk brakes front and rear
Roll over bar
Neutral light
Change indicator oil temp
Oil pressure light
As you can see from the pictures, I have taken the bodywork off in prep to install a different body. The plan has been put on hold with a big house renovation project going on, and the space, money and time is needed for other things sadly. So it need bodywork of your choice, lights and a handbrake cable replacing (it snapped). The interior is very basic and geared towards lightness rather than refinement.
Starts and runs. Not a 'category' car in terms of insurance. Registered on a Q plate. The car starts, drives and everything works.
Collection from Bristol, or can deliver for an agreed price
£3500
PaulYDP
posted on 30/7/19 at 02:49 PM Reply With Quote
I had been in talks to buy this when it was for sale a few weeks ago but you beat me to it! Good luck with the sale....
ch1ef
posted on 3/8/19 at 07:12 AM Reply With Quote
Deposit taken
