Author: Subject: 2” / 52mm tachometer old style
trextr7monkey
posted on 29/4/20 at 05:24 PM Reply With Quote
Hi
Busy redoing dashboard and am looking for a smaller tachometer gauge that will match existing clocks, not digital readout or LED or anything modern. It’s for the x flow powered jeep so doesn’t need a massive range I suspect I might have a small Tim item but can’t find it at the moment so something along those lines.
Have had a quick scout on eBay but nothing obvious there.
Mike
Mike Wood
posted on 29/4/20 at 07:25 PM Reply With Quote
VDO sell 52mm diameter rev counters: https://www.merlinmotorsport.co.uk/s/instruments-gauges-senders/vdo-gauges-and-senders/vdo-cockpit-vision-gauges
Smiths too:
https://www.holden.co.uk/p/smiths_classic_tachometer_52mm_dia_black
If you can go to 80mm or 100mm there is more choice from VDO, Smiths, Ractech etc. E.g https://www.holden.co.uk/p/smiths_classic_80mm_max_hand_tacho_0_8_000_rpm
Mike
[Edited on 29/4/20 by Mike Wood]
MikeR
Contributor
Posts 8600
Registered 25/5/02
Location Hinckley
Member Is Offline
Photo Archive Go!
Building: Slowcost since 2000, speeduino since 2020, Caterha
posted on 29/4/20 at 07:42 PM Reply With Quote
car builder solutions have some. A quick search found this, although i'm sure they do a pack of three gauges for 36 quid which i think has a tacho.
https://www.carbuilder.com/uk/2-electronic-tachometerrev-counter
Mike Wood
posted on 29/4/20 at 07:51 PM Reply With Quote
Also Durite:
https://www.holden.co.uk/p/tachometer
https://www.vehiclewiringproducts.co.uk/c-1-home/c-53-gauges/c-125-durite-vehicle-gauges-fittings/p-207-tachometer-12v
(Probably a good budget option)
trextr7monkey
posted on 30/4/20 at 08:53 PM Reply With Quote
Thanks for the steers, VDO items are a bit expensive and over kill for this application. The fruited one could be a runner!
Mike
