Author: Subject: Brake pipe clipping
Crockpot
posted on 8/5/20 at 01:13 PM Reply With Quote
Brake pipe clipping
I've been looking through the posts on brake pipe clipping. I know about spacing of clips etc but cannot find anything that helps in my case.
I had planned to clip every 200-250mm but the pipe in between would be in free space i.e. not against a panel. It would appear that the testers frown on this, although not explicitly prohibited in the manual.
It's an easy fix at this stage so any thoughts on it?
Slimy38
posted on 8/5/20 at 02:44 PM Reply With Quote
How 'free space' are you talking? If it's possible to damage it by a rogue foot or bag of luggage then yes I'd say it can't be free. For me the reason for it to be against a panel is so it can't be damaged.
If it's away from a panel to avoid a sharp corner round a metal bar or moving part then that is probably a bit better.
gremlin1234
posted on 8/5/20 at 02:50 PM Reply With Quote
Originally posted by Crockpot...It's an easy fix at this stage so any thoughts on it?
I think you know the answer, route it properly, one less thing to fail on.
ianhurley20
posted on 9/5/20 at 08:19 AM Reply With Quote
Inside the transmission tunnel I put a strip of aluminium about 50mm wide fitted to the frame and use this to attach brake pipe and also flow and return fuel pipes. Straight run and supported every 200mm or so with clips. The clips I used had a single 6mm push fitting and spaces for two 8mm pipes and one 5mm which was perfect
My build blog http://ianhaynes20.wordpress.com IVA passed 3/10/16
written off 23/9/18
Aug 2019 completed Tiger Avon with ST170 on TB's
Now restoring 1968 Ginetta G4
And - a series 1 Land Rover - don't ask why!
CosKev3
posted on 9/5/20 at 09:22 AM Reply With Quote
If a car manufacturer did it you could get away with it,but you never see a brake pipe that's not running on solid chassis/floorpan on a production car so theres your answer!
Crockpot
posted on 9/5/20 at 11:04 AM Reply With Quote
Thanks. Change of plan it is.
posted on 9/5/20 at 06:11 PM Reply With Quote
Did the same.
