Author: Subject: Sierra diff information
Shemster65
posted on 6/12/20 at 12:50 PM Reply With Quote
Hi
Can anyone tell me if there is a 7.5” Sierra diff with a 3.14 ratio available or if 7” crown wheel and pinion will fit into a 7.5” casing ?
mcerd1
posted on 6/12/20 at 03:21 PM Reply With Quote
I've heard of 7.5" diff's with 3.14 ratio's, but never actually seen one for sale (I suspect they were like rocking horse poo, even when these cars were new)
I believe the 3.36 raito 7.5" diff's may have been a little more common in europe, but the 3.64 is far more common - have you had a look here:
https://www.locostbuilders.co.uk/forum/9/viewthread.php?tid=85080 ?
or here for more info:
http://www.super7thheaven.co.uk/components/sierra_rear_differential/
I don't believe you can fit a 7" CW&P into the larger casting - they aren't interchangeable like that
but you can mount a complete 7" diff casing in pretty well an chassis / read beam meant for a 7.5" - all it takes is some different bolts and spacers
(the 7" uses 2 long through bolts in place of 4 of the short ones on a 7.5" )
quite a few kits were made to fit either size diff in this way - including my rush
only issue you might have is with driveshafts - it just depends which type and what size you have now (the 100mm bolt-on type will be the easiest, as they are the same on both diff types)
fregis
posted on 9/12/20 at 01:41 PM Reply With Quote
7.5 gears are much biger than 7,
also main gear 7.5 use 12 bolts, 7 use 10 bolts.
Also 7.5 center part mauch wider compared to 7
because diferent size of gears i gues it not fit correctly.
i tried 7" gears put to 6.5 diff, almost indentical, but have ~5mm pinion gear offset.
Never be afraid to do what you are insolvent, remember: amateurs built the ark - Professionals built the Titanic.
Shemster65
posted on 9/12/20 at 08:43 PM Reply With Quote
Ok thanks for the info
HappyFather
posted on 10/12/20 at 09:14 AM Reply With Quote
What about putting the contents of a 7" diff inside a 7,5" casing? Would that work?
A couple years ago I was dreaming about getting a 3,14 LSD 7,5" diff to replace my 3,62 open 7,5". To achieve that I was planing to get a 7" 3,14 and use the CW&P on a 7,5" LSD of any ratio. I had to postpone/abandon the idea (failed to get road legal, divorce, oth€r prioriti€s), but now I wonder if it would have been possible at all. I had been told by a drift guy that welded diffs that it was possible but never found confirmation online.
