Author: Subject: WTD: Type 9 alloy bellhousing
pekwah1
posted on 1/4/18 at 11:53 AM Reply With Quote
Hi guys,
Just on the off chance while I have my engine out, does anyone have an alloy type 9 bellhousing to go from a 5spd to a blacktop zetec 4 pot?
[Edited on 1/4/18 by pekwah1]
Paul A
posted on 2/4/18 at 04:32 PM Reply With Quote
I have an alloy bh, modified to infill the os cut out for the clutch arm (it was rs so now only has started recess on near side) so suitable for hydraulic clutch only. Not the best so just want £60+ postage. I have pics but can't see how to insert them being an IT dinosaur!
Paul A
pekwah1
posted on 2/4/18 at 05:04 PM Reply With Quote
Hi, I’m still running a cable clutch and not looking to upgrade to hydraulic at the moment...
Is the modification permanent, I.e I couldn’t just cut the infill back out?
obfripper
posted on 2/4/18 at 05:40 PM Reply With Quote
The os cutout needs removing to fit into a striker anyway, you'd need to add a clutch cable bracket and a slot into the infill for the clutch arm to operate, and reuse the arm/release bearing/pivot pin from your existing bellhousing (there may be some mods needed to the arm for this) .
The rs2000 bellhousing does have the starter mounting in a slightly different orientation, so your dust shield will need new holes for the bolts.
Dave
