Author: Subject: BMW engine won't start
PSpirine
posted on 23/4/10 at 03:59 PM Reply With Quote
I've got a M43 (318ti) engine that had a failed gasket (bought like that - never heard it running). I changed the gasket, put it all back together, but the bastard won't start.
It cranks well, and makes a boomy pop once in a blue moon.
Definitely getting petrol (plugs flood very quickly since it won't fire). I've taken out a plug and tested it and it sparks VERY intensely, so it's getting fuel + spark.
What the hell else could be wrong? I tried spraying some Easy-start into the intake, but it hardly did anything.
It sounds like it wants to catch, but doesn't.
Spark plug leads are all numbered and in the correct order (1 at front, 4 at rear).
I've got two thoughts:
1) I put the cams/cam sprockets back incorrectly. They won't be massively out as they were marked before taking the cams off, and the sprockets were ziptied to the chain and each other so they're in time. The only thing that could've happened is if the cam is slightly out (as the sprocket-cam fixing is adjustable), but this wouldn't be more than a couple of degrees. I can dismiss majorly incorrect reassembly on the grounds that it would've hit the valves on the piston if it was way out (i.e. cam 180 degrees out).
2) Bad fuel. I've heard that unleaded can 'go off' but I've never experienced it even with cars that hve been standing for about 8 months. By my estimates the last time this BMW engine ran was approx 14 months go. Could it have gone off THAT badly that it won't even catch? If so, why doesn't easy start help? (I'm squirting it in, then going in and cranking as I don't have telescopic arms to reach the ignition key from the engine bay).
I'm just struggling to find what else to check as it SHOULD be running but isn't!
Pavs
jossey
posted on 23/4/10 at 04:06 PM Reply With Quote
ermmmmm
bmw engines are a pain when taken out.
here is a few things to try.
lining up of the cams is a maybe i guess.
the next thing is the ecu looking for the key immobilser .... thats an issue with alot of bought engines.
have you bought the diagnostic tool for the engine? that would check what maybe the problem
bad fuel is unlikely to be an issue. you can test the fuel by putting the spark plug with ht lead in a metal container with maybe a 3rd of a cup of fuel in it. if the fuel goes up it is working. best not to try this indoors.
last thing is try spray WD40 into the ports where the sparkplugs are and fit the plugs and try that.
i have a e60 engine which was a nightmare to start. turned out to be immobiliser issue. but the bmw forum suggested the above.
see if that works.
dave
David Johnson
Guinness
posted on 23/4/10 at 04:07 PM Reply With Quote
Check the compression.
You are getting two out of the three things you need to make bangs.
Mike
55ant
posted on 23/4/10 at 04:10 PM Reply With Quote
ignition timing could be out by 180 degrees?
away from cars, now cycling and building TT bikes
dlatch
posted on 23/4/10 at 04:24 PM Reply With Quote
check ecu for fault codes
if the crank or cam sensor is playing up its not gonna start
[Edited on 23/4/10 by dlatch]
PSpirine
posted on 23/4/10 at 04:39 PM Reply With Quote
Thanks for the responses guys, the engine is still in the 318ti car so has all the wiring connected etc.
Re: Immobiliser, Crank sensor - if either of these were at fault (or disconnected) then the ECU cuts fuel and spark (I know this because I was getting no fuel and no spark because I forgot to plug back the crank sensor connector when putting the engine back together). Therefore I doubt it's this.
When cranking, dash doesn't show Check Engine light.
Regarding spark, I'm not sure how it could be 180 degrees out, as it's a coilpack that is clearly labelled 1-2-3-4 and the HT leads going from it are labelled respectively.
Is it worth taking the cam cover off and turning it over by hand to make sure I haven't put a cam in 180 degrees out? I would've assumed this would've been evident due to valve-piston interference..
How much would cam timing need to be out to prevent it from even roughly starting?
Pavel
zoom
posted on 23/4/10 at 05:29 PM Reply With Quote
I think you need to do a compression test first.
mycar
mybuildsite
posted on 23/4/10 at 07:04 PM Reply With Quote
That would be my bet --- the pop once in while is a big pointer to this. swap leads 1 onto #4 and 4 onto #1 2 onto #3 and 3 onto #2.
PSpirine
posted on 23/4/10 at 08:04 PM Reply With Quote
I already tried reversing the ignition leads, to no avail (plus I'm certain that's not the problem as when reversing them, plug #3 doesn't reach the spark plug hole without a stretch).
Will try get hold of a compression tester and check that!
Cheers everyone
