Author: Subject: Need a machine shop to fit two helicoils to a small engine for me
carpmart
posted on 21/9/14 at 05:36 PM Reply With Quote
Chaps
I've a small 30cc 2 stroke engine I use in my RC car. It's stripped the thread a couple of times where it bolts the exhaust Manifold on. I've drilled and remapped this but it's ultimately not held. I need to helicoil it. I'm in Bedfordshire and work in maidenhead and Newbury quite a bit. Anyone know somewhere I could get this little job done?
[Edited on 21/9/14 by carpmart]
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
ian locostzx9rc2
posted on 21/9/14 at 06:25 PM Reply With Quote
Couldn't you buy a set off eBay and do it yourselve the sets on eBay are £10 to £15!
rick1962uk
posted on 21/9/14 at 06:30 PM Reply With Quote
what size thread is it you need
carpmart
posted on 21/9/14 at 07:00 PM Reply With Quote
ive got a failed M5 thread at present
'94 MX5 MK1, 1.8
carpmart
are they any good and can you link me?
'94 MX5 MK1, 1.8
ReMan
posted on 21/9/14 at 07:09 PM Reply With Quote
Like so? THREAD REPAIR KIT METRIC M5 5MM CAN BE USED WITH HELICOIL INSERTS
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
rodgling
posted on 21/9/14 at 07:11 PM Reply With Quote
Looks like the kit I used for my calliper brackets on the 7, it was quite easy and gave a good result.
big_wasa
posted on 21/9/14 at 07:22 PM Reply With Quote
What size did you re tap it out to ?
If you just ran a tap through the M5 you will be able to use an m5 kit. If you went to M6 You will need an M6 kit. Is there enough meat to tap it for the insert ?
A quality M5~M6 kit will set you back £20~£25 but to be honest a cheap ebay kit should be fine for what you need and its quicker to do it your self than get in the car and take it some where.
carpmart
posted on 21/9/14 at 07:37 PM Reply With Quote
thanks for all the advice fellas, I've splashed out on an eBay special kit, should be fine for what I need!
'94 MX5 MK1, 1.8
