Author: Subject: Rear seat anchors
metel matt
posted on 22/3/16 at 12:38 PM Reply With Quote
Rear seat anchors
Gents
I'm after a bit of help with the rear harness anchor points. I've just been reading through the IVA manual and I would like to clear something up. Is the rear mounts classed as exterior projections or interior. If it is more than 250mm from point R (being the base of your seat) it is classed as exterior. So if it is classed as Exterior I only need to have the edges of the anchor point on he harness blunted if less than 5mm thick meaning I don't need to put some padding on for IVA only put a nut cap on. Or what have you guys done in this area to pass IVA?
I hope you under stand what I'm trying to say because I don't.
cheers
http://www.locostbuilders.co.uk/forum/50/viewthread.php?tid=202165
Slimy38
posted on 22/3/16 at 02:47 PM Reply With Quote
I don't have an IVA manual to hand (first time for everything!), but I seem to remember the 'interior' stops at the back of the seat, it's not just a distance from the base.
I'm almost certain I've never seen padded seatbelt anchors, only capped.
adithorp
posted on 22/3/16 at 03:46 PM Reply With Quote
They're exterior. Plenty of people have failed on them in the past. Either edge trim or covers knicked from tin-tops in the scrap yard are the usual way.
http://jpsc.org.uk/forum/
