Author: Subject: Engine to far back??
steve-hv8
posted on 17/8/16 at 03:46 PM Reply With Quote
Think I've messed up big time here
[/URL]
Sam_68
posted on 17/8/16 at 04:54 PM Reply With Quote
Time to start looking for a concentric slave cylinder?
posted on 17/8/16 at 05:06 PM Reply With Quote
The clutch fork will move backwards as the clutch disc wears, ideally move the engine forward at least 15mm.
r1_pete
posted on 17/8/16 at 08:00 PM Reply With Quote
Definitely an oh f**k moment, but a concentric cylinder would probably be easier than shifting the engine forwards.
Its the sort of thing we've all done, my moment was welding a set of throttle body runners on the wrong side of the flange.
Sam_68
posted on 17/8/16 at 08:12 PM Reply With Quote
Look on the bright side - it'll probably improve your weight distribution a tad!
davew823
posted on 18/8/16 at 11:30 AM Reply With Quote
Clutch arm
Cut back 90% of the sub-flange on the arm so it clear the rear frame tube. Then plate the front side of the lever with solid 3/8" flat stock along with a relief hole in the flat stock for the slave push rod. Dave W
steve-hv8
posted on 18/8/16 at 05:18 PM Reply With Quote
Bit of work done today
Engine and box removed again
All three mounts cut off
Engine and box back in again
Sitting a lot better now and a bit lower so that will help with the body work
Just need to tackle engine mounts in and make a new gearbox mount
gremlin1234
posted on 18/8/16 at 05:33 PM Reply With Quote
you make it sound so simple ;-)
steve-hv8
posted on 18/8/16 at 07:39 PM Reply With Quote
It's not to bad just a bit of a pain cutting the mounts
