chassis plans
Julian B - 17/4/17 at 05:23 PM
Hi All
Spent the day making a build table as ive decided to dip the toe back in again . I thought the first bit would be easy but after spending a couple of hours im no closer to finding an answer
The question is does anyone one have a set of plans for a locost based on a MX5 . I have seen a few posts on this but no links that seem to work
Any help much appreciated
big_wasa - 17/4/17 at 06:26 PM
There is the Saturn modifications to the he Haynes roadster ?
http://www.roadster-builders.co.uk/viewtopic.php?t=674
chris_smith - 17/4/17 at 06:50 PM
I'm currently building the Haynes roadster incorporating the Saturn plans using Mx5 running gear
Slimy38 - 17/4/17 at 07:11 PM
The plans may seem incomplete because they're based on the 'build a car on a budget' book. As far as I know, there are no complete sets that are online only, you have to buy the book and then the various modification documents will make sense.
Julian B - 17/4/17 at 07:28 PM
Thanks for the info guys that gets me underway . I gave my book away about 5 years ago but i have a hankering to build somthing with the lexus V8 lump . I think its going to be a squeze but hey ho nothing ventured etc
I have loads of questions but one at a time i guess
Cheers all
Talon Motorsport - 17/4/17 at 07:31 PM
Basic version of my mx5 TMXR chassis drawings, download Google Sketchup it allows you use the tape measure and protractor.
https://3dwarehouse.sketchup.com/model/aea30683-a8c0-4866-a7d4-2ccc67042bc6/Haynes-Roadster-TMXR-rear-suspension
TDH1138 - 23/4/19 at 05:16 PM
Hello all.
I am having trouble getting any links to free plans to download.
I am mostly interested in plans that use the MX5 as a donor.
There is Voudo and Saturn, but I can't seem to find a downloadable set of plans that are complete.
What I have found, either is not for an MX5 or there is missing details or dimensions.
Or the link just will not work.
Lots of nice 3D pictures showing good looking designs.
But not the total package.
At this point, I'm thinking of just doing my own thing using existing ideas as inspiration.
Is this normal?
Or have I not gone far enough down the rabbit hole?
Please help if someone can.
Maybe re-post the link?
Do these things time out?
I'm no computer surgeon, so that may be my problem.
But I know how to click on a link.
Slimy38 - 24/4/19 at 02:53 PM
Originally posted by TDH1138
Hello all.
Is this normal?
I'm fairly sure both Vodou and Saturn build on the 'build your car on a budget' book, making changes as required for the MX5. So I'm not overly surprised there isn't a 'complete' set of plans. (I've never seen the book itself available for download).
Having said that, even with the Saturn plans and the book, I still had to come up with a few things that work best for me. For example, the MX5 designs use a complete rear diff with mounting points for the 'arms' of the standard diff. I didn't want to do that as I've seen several instances of those arms becoming a weak point. Talon put together a diff case for the MX5 diff so I bought one of those. This meant I could get closer to the Sierra wishbone layout as well as the diff mounting.
