New Topic New Reply
Author: Subject: Chassis bought - 50mm brackets
fuzzy!!
posted on 13/9/07 at 04:36 PM Reply With Quote
...so I bit the bullet and bought a chassis - looks good to me other than we have 50mm mounting brackets all round drilled for 3/8ths bolts.
Is this a fairly common combination?
Anyone know where I can get hold of the bushes? as I need to get on and try and build the wishbones and trailing arms - unless anyone has something spare in these dimensions? I think it's all book otherwise.
thanks
MikeR
posted on 13/9/07 at 05:07 PM Reply With Quote
triumph herald bushes - try you local motor factors.
Or you could drill them out to 10mm
or you can now get powerflex bushes in 3/8ths .
t.j.
posted on 13/9/07 at 06:29 PM Reply With Quote
Dr. Fastlane and I use peugeot 205 bushes. inner is original 10 mm. I drilled them up to 12 mm.
It's all to you what you like.
Grtz
New Topic New Reply
