big_wasa
posted on 27/7/06 at 08:51 PM |
32mm,
Can not aswer the sender question yet.
I also have another rad to play with...
ned
posted on 27/7/06 at 09:37 PM |
James,
not sure what the sender is off but its a common size, £6-8 for one if yours doesn't fit.
Ned.
beware, I've got yellow skin
Fozzie
posted on 27/7/06 at 09:41 PM |
quote: Originally posted by James
Not that I don't love my Micra rad, but!
What size are the inlet/outlet hoses on the Polo please?
And which temp sender have you used? It's Sierra one that's compatible right?
James
James the temperature sender that you require should be compatible with your temperature gauge.......it doesn't need to be compatible with owt
else.
The transmitter (sender) , transmits a voltage to the gauge, which transfers this to a reading to the gauge.
A transmitter NOT compatible to the gauge will give a 'wrong' reading. Hence sender and gauge must be compatible....
HTH Fozzie
James
posted on 27/7/06 at 11:48 PM |
meant temp' switch for fan.... sorry!
James
- Muhammad Ali
Fozzie
posted on 28/7/06 at 08:26 AM |
James
Doh! ....... ![](/images//smilies/bigsmile.gif)
Fozzie
