New Topic New Reply
Author: Subject: Height of 1.8 Zetec silvertop in book chassis
maartenromijn
posted on 31/7/09 at 10:25 AM Reply With Quote
Hi. I have done some searching, but could not find the info I need.
This weekend I will fit the 1.8 Zetec (silvertop) from a 1993 Mondeo and MT75 gearbox into my book chassis.
The sump has not been modified, I will modify it later on.
What would be the correct height of the engine? I know normally you don't want the sump sticking under the chassis more then 1". Since my sump has not been modified yet, what could be my reference point??
Does the height of the gearbox output shaft matter?
BLOG: http://thunderroad-super7.blogspot.com/
Surrey Dave
posted on 31/7/09 at 12:05 PM Reply With Quote
Very Tall for Book chassis
Even with a very short sump, the engine would have to be hung low, probably 2" below chassis, then you would still need a high nose and bonnet or a bulge on the bonnet.
[Edited on 31/7/09 by Surrey Dave]
UncleFista
posted on 31/7/09 at 12:40 PM Reply With Quote
The cam pulleys have 2-3mm clearance from the bonnet on ours, and even with a cut and welded sump it hangs low below the chassis.
As Dave says, it's a very tall engine for a book chassis.
We managed to do without any holes in the bonnet though [1].
[1] We actually have a big hole in the bonnet, but it was for the carb on the crossflow
Tony Bond / UncleFista
maartenromijn
posted on 31/7/09 at 12:55 PM Reply With Quote
I do not mind a bulge on the bonnet. Just need a reference point for correct placement of the engine.
First I want to install the engine. Worrying about the bonnet/ nosecone can be done later...
big_wasa
posted on 31/7/09 at 03:38 PM Reply With Quote
With a 165mm sump and only 15mm below the chassis Mine just fits under the gts fiberglass which is around 3/4 to an 1" taller than book
Surrey Dave
posted on 31/7/09 at 04:04 PM Reply With Quote
Yes
If I ever get round to fitting mine , I plan a much shallower sump than 165mm, but it will still probably poke out of back of the nose cone..
Mark Allanson
posted on 1/8/09 at 11:41 AM Reply With Quote
MikeR
posted on 1/8/09 at 04:03 PM Reply With Quote
my plan is sump 1" below, stuart taylor body work and bump on the bonnet. The stuart taylor bodywork is 1" smaller than the GTS so it should all be nice and snug.
(once i've got through IVA with the crossflow).
New Topic New Reply
