Author: Subject: Tiger Avon engine position
andy350z
posted on 26/8/09 at 07:10 PM Reply With Quote
I'm having a Zetec fitted to my Avon.
The mechanic has just called as he wants to make sure the position is correct before he cuts the exhaust hole.
Using Tigers engine mounts the engine is 3/4 inch lower at the front than the back. Is this correct? He couldn't get hold of anyone at Tiger today to ask
Thanks,
big_wasa
posted on 26/8/09 at 07:56 PM Reply With Quote
I would want it level imho
Ian D
posted on 26/8/09 at 08:52 PM Reply With Quote
I fitted mine with the Tiger supplied mounts. It does slope to the front. You cant go higher because the nose cone and bonnet do not have enough height to raise it. The real trick is to position it so that the prop shaft is inserted in the gearbox and so that you have clearance for the starter motor against the chassis, plus on the otherside space to get the oil filter out without fouling the steering shaft. I would play with it before drilling holes.
Hope this helps.
Ian
clairetoo
posted on 27/8/09 at 06:22 AM Reply With Quote
That dont sound good - can the gearbox mount be lowered at all ?
Its cuz I is blond , innit
Claire xx
Will weld for food......
edspurrier
posted on 27/8/09 at 07:50 AM Reply With Quote
Mine slopes slightly down at the front, but as long as the starter and filter clear it's fine.
t.j.
posted on 29/8/09 at 08:27 PM Reply With Quote
is your diff also angled downwards?
If not then level the engine.
you want balance in your propshaft.....
