kennyrayandersen
posted on 23/9/09 at 03:57 PM |
size matters
Could one of you resident experts list, from smallest, to largest, the various 7 versions? I'm actually trying to get one that is about the
same size as the S3 Caterham, which I think is just a little larger than the earlier ones.
posted on 23/9/09 at 04:21 PM |
You'll struggle to get anything as small as a Caterham S3... I had one years ago and it was MUCH smaller than any kitcar I've been in
since.
shaun fulcrum
posted on 23/9/09 at 05:07 PM |
I think strikers are one of the smallest 7's, I can't think of a smaller one though so possably the smallest!?
Sorry that I can't be more helpfull.
Steve Hignett
posted on 23/9/09 at 08:04 PM |
Striker is the tiniest bit smaller, then Caterham S3 and Pre-Lit Westy the same size. Oh, and the Birkin is also the same size as the S3...
andrew.carwithen
posted on 23/9/09 at 08:51 PM |
I'd say the Tiger Avon is very similar in size to the Caterham. (it's certainly smaller than an MK or MNR, for example.)
The Sylva Riot is 'sevenesque' in appearance and is tiny.
Madinventions
posted on 23/9/09 at 09:36 PM |
The Mojo (linky1, linky2) is a kind of modern take on the seven style
with open front wheels and winged rears, and is truly tiny. It's basically the same chassis as the Riot but with a fuller bodyshell.
Here's mine next to a Toyota Yaris which aren't particlarly large cars either!
Ed.
build diary here
View my band website:
http://www.shadowlight.org.uk
kennyrayandersen
posted on 23/9/09 at 10:46 PM |
how does the Fisher Fury, or Phoenix compare?
Hmmmm so the Striker is the small one? See, that's what I mean by the pictures being deceptive. Since the Fulcrum is built on the same
chassis, then I'm guessing it's pretty small as well.
That explains how someone got that S2000 lump in the MK -- it looked like it fit reasonable well, which surprised me.
I guess I'm trying to avoid at least the extra large 7 versions.
MikeR
posted on 23/9/09 at 11:47 PM |
Aries is based on the locost chassis which is the same as a pre-lit westy I believe.
It also uses the smaller body work so is proportioned closer to a caterham.
