<<  1    2  >>
Author: Subject: buying a classic mini
cd.thomson
posted on 22/12/09 at 09:41 AM Reply With Quote
Mornin'!
Dax should be on the road by spring then I really need to start looking for a new car to bomb around in when the weathers bad. This becomes clear when you spend half the time cycling to work sideways
Wont have a lot of money (have to save for uni..again) but really like owning "special" cars. 2 doors is a must.
Soo I'm starting to investigate classic minis, any tips? pros/cons? is there a standard route that can be taken to "improve" them? Worth buying one if I can't weld?!
[Edited on 22/12/09 by cd.thomson]
Craig
carpmart
posted on 22/12/09 at 09:44 AM Reply With Quote
Easy to improve them!
Rip out the engine in the front and stick a Honda VTEC in the back, great improvement!
However, answering your other question, its not worth buying one if you can't weld!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
Mr Whippy
Hmm there’s not much metal at all in a mini so you’d have to buy one that was in very good condition, even then their very flimsy.
I actually passed one on the way to work in the snow and I’m sure its great fun, what puts me off is getting hit by anything else as you’d be better just bailing out and taking your chances.
cd.thomson
posted on 22/12/09 at 09:48 AM Reply With Quote
nuff said!
might be worth learning though? I mean I've heard rumours that people build entire cars from separate bits of metal , I'm sure patchworking a mini is a doddle in comparison!
Craig
Mr Whippy
posted on 22/12/09 at 10:01 AM Reply With Quote
nuff said!
one problem with the mini is that like the vw beetle, a lot of the panels are crimped and spot welded flanges i.e. the huge gutters all round the car. These are tricky to repair if they have rusted in the channel with an noramal mig. I've done it on my current bug project in a few places and it needs very neat work.
I'm not trying to put you off but just pointing out that despite being a simple car it’s not very simple to repair than say a more conventional body shell.
For example, the front needs very good alignment (using a jig) to be replaced as there's no front chassis rails to weld to and keep things straight, just an inner and outer wing. The front engine/suspension sub frame is just held on with 4 bolts and requires the body to keep it aligned correctly. So if it’s rusty and needs repairs this will not be quite as straightforward to rectify.
[Edited on 22/12/09 by Mr Whippy]
ali f27
posted on 22/12/09 at 10:05 AM Reply With Quote
mini
Hi i have had numerous minis best car ever made yes they rust and build quality on late ones is crap but can be made to out handle anything i have seen off a lot of so called gti hot hatches still own 2 as well as the 7 just buy 1
posted on 22/12/09 at 10:09 AM Reply With Quote
What about another 205?
Granted a non GTI 205 may not be "special", but they're dead cheap and don't suffer from tin worm like other cars. The little 1.3 TU series engine can be quite peppy and as you know the cars weigh less than a tin of biscuits.
alistairolsen
IMO building my locost chassis was a LOT easier than doing panelwork in a paper thin rusty monocoque using pattern panels profiled by a blind chinaman.
My Build Thread
cd.thomson
posted on 22/12/09 at 10:17 AM Reply With Quote
I can actually afford the insurance on a 205 gti despite my accident but fancy something different.
Sounds like mini's aren't the option to go for though.
I'd also considered a fiat 126 but id want to be heavily modifying it from the off whereas id be happy with the mini as standard until I had some more wonga to throw at it.
back to the drawing board!
Craig
ali f27
posted on 22/12/09 at 10:23 AM Reply With Quote
mini
find one to have ago in that will make your mind up bet you love it
StrikerChris
posted on 22/12/09 at 10:25 AM Reply With Quote
Hillman imp?!
posted on 22/12/09 at 10:34 AM Reply With Quote
In good condition they are no more dangerous the most other cars of the era, in fact safer than many. The problem is that a rotten mini has the structural integrity of a wet paper bag, and there are an awful lot of rotten minis around.
If you want to own a classic mini then you either need to pay the money demanded for a really clean one or get yourself familiar with welding (unless you know a mate who will help out etc.). Well worth having a drive in a nice one though, even with a 34bhp 848cc engine they are a lot of fun to drive, and a well sorted 1275 is a blast to drive through B roads.
One big bonus is that its probably the best supported "classic" car around, there is pretty much nothing that you can't buy new and tuning options are huge.
[Edited on 22/12/09 by MikeRJ]
cd.thomson
posted on 22/12/09 at 10:45 AM Reply With Quote
hillman imps seem to be suprisingly rare!
I think im going to try and get on a welding course at college and see how well I pick it up, then decide on the mini option then.
I could always buy a rotten mini and buy a reshell and just move the parts across!
Craig
Mr Whippy
posted on 22/12/09 at 11:35 AM Reply With Quote
thought you wanted to buy a car to use while the weathers bad? it will be months just to get that done and far more expensive than just buying a good example in the first place.
A welding course will only teach you how to weld, not rebuild body shells that is two totally different things.
I bought yet another very rusty beetle that I knew needed extensive work cos I wanted to rebuild another car. It cost at least £1200 in repair panels (I still had to make quite a few) and I'll never get what I spent on it back but that wasn't the point of doing it anyway. Its fun to do and very satisfying to see it put back together from something that was destined to go to the crusher but still a big commitment in time and money, definitely not a quite fix.
If you want to learn how to rebuild classic cars that fine but don’t think it will be cheap or quick to do, cos it isn’t.
hicost blade
posted on 22/12/09 at 11:36 AM Reply With Quote
Mk1 escort
http://cgi.ebay.co.uk/FORD-ESCORT-mk1-1600cc_W0QQitemZ130353461932QQcmdZViewItemQQptZAutomobiles_UK?hash=item1e59abfaac
or a
Mk2 escort
http://cgi.ebay.co.uk/Mk2-1976-FORD-ESCORT-WHITE_W0QQitemZ300377703216QQcmdZViewItemQQptZAutomobiles_UK?hash=item45efe80330
When it rusts into the ground, turn it into a Locost
Only problem is the 5 family doors, but who cares!?!
[Edited on 22/12/09 by hicost blade]
cd.thomson
posted on 22/12/09 at 11:42 AM Reply With Quote
Sorry, what I meant was in future I'd like to end up with a car I can use all year round unlike my dax/road bike.
I'm after something a little special and really like minis - the welding/restoration side of things came up as this is obviously a consideration with any old car but I don't intend on restoring a scrapper.
The rotten mini/reshell idea was me joshing around because it sounds like they're so bad!
Its hard to get across what you mean on a forum lol
ETA- I do like 2 door MK1 escorts which could be had for a similar price to the minis im looking at, but I presume they take just as much work.
Craig
stevec
posted on 22/12/09 at 11:49 AM Reply With Quote
There is a garage on the A46 south of Nottingham near Ratcliffe on the Wreake that has loads of old mini's stacked on top of each other.
Bet you could get a cheap project there.
posted on 22/12/09 at 12:10 PM Reply With Quote
Yes they rot very well, and they fetch ridiculous money these days. You could get yourself a tidy mini for the price of a very rotten Mk1.
Jasper
posted on 22/12/09 at 12:29 PM Reply With Quote
I bought a classic Mini last week. I wouldn't even consider one with a rotten body ( i hate welding old thin panels), which is most of them, but there are a few around that aren't rotten, recon to pay £1.5k + for one that doesn't need lots of work.
However, they are really cheap to repair and SO much fun to drive. Drove mine back from Marlborough last Tuesday and really enjoyed bombing along the A272 back home.
I paid £4k for a 2000 W reg Cooper Sport, FSH, completely immaculate, 60k on the clock, new MOT and tax and even a new set of tyres not even put on the car yet. Owned by a mini club lady, who cried as I drove it away, it was very well loved. Book price is at least £5k on that car, just bought it at the right time of year.
Gonna fit the Stage 3 kit in a few months time, takes it up to 90bhp which should be a laugh!!
It's a bit like driving a kit car, really brings a smile to your face, put you can use it all year round
DarrenW
posted on 22/12/09 at 12:53 PM Reply With Quote
Minis are easy.
1. Learn to weld.
2. Only bits to watch out for are between front and rear bumper.
I wish I had more time to finish mine. I'm assuming Jasper doesn't want to come and see mine now so if you are intested I can sort you some pics out.
[Edited on 22/12/09 by DarrenW]
Jasper
posted on 22/12/09 at 01:50 PM Reply With Quote
Yeah - sorry Darren, didn't hear from you and saw one locally at a good price that needed nothing done, I'm sure you understand
Now if you had a been a bit closer ....
[Edited on 22/12/09 by Jasper]
minordelay
posted on 22/12/09 at 05:03 PM Reply With Quote
Chap I work with at college (panelbeater) has just bought an 83 mini 1000 as an interesting project. He's spent nearly £1200 on panels so far and hasn't even started welding yet
1275 engines getting rare now, he paid 450 for full running gear out of low mileage MG metro.
I'm sure it'll be nice when done though, you've gotta love the mini.
McLannahan
posted on 22/12/09 at 05:22 PM Reply With Quote
Craig - What about a Mk1 Golf GTi?
imp paul
posted on 22/12/09 at 05:25 PM Reply With Quote
sod the mini get a imp sport
[Edited on 22/12/09 by imp paul]
COREdevelopments
posted on 22/12/09 at 06:48 PM Reply With Quote
Get a mini. it will put a smile on your face all day long. An imp would be great too but they are like rocking horse poo!! and have never driven an imp before!
my mate bought a 98 cooper mpi. drives beautiful too. think it cost him just under 2000k
Rob
<<  1    2  >>
