New Topic New Reply
Author: Subject: chassis drawing
Cita
posted on 18/7/04 at 06:30 AM Reply With Quote
chassis drawing
I'm fooling around with the scanner (new toy) Rescued attachment Scannen.jpg
Cita
posted on 18/7/04 at 06:31 AM Reply With Quote
This is obvious going wrong!!!!!
posted on 18/7/04 at 09:59 AM Reply With Quote
What are you scanning them into?
You can change their size in an image manipulation program ( Photoshop type) or you can scan them at a percentage of their original size.
Cita
posted on 18/7/04 at 10:04 AM Reply With Quote
I know Pete it looks like s@#t but i know not much about this computer stuff.
If anyone can bring it (the drawing i mean to a reasonable size....)
posted on 18/7/04 at 10:05 AM Reply With Quote
Shrunk to 600 pixels across.
Here they are. If you export them as .jpeg you can cut down on their quality and still show them but save space and time uploading.
posted on 18/7/04 at 04:25 PM Reply With Quote
For line drawings you really want to avoid jpeg and stick with GIF or some other lossless compression. You can often get as good or better compression and you don't get the artifacts around the lines.
crbrlfrost
posted on 18/7/04 at 10:49 PM Reply With Quote
Is that a swingarm monoshock rear suspension? What are you using for roll control?
posted on 18/7/04 at 11:18 PM Reply With Quote
I meant for general pictures for web publication really. The ones on there are .bmp, check the properties. Look round on Google for scanning tips. This one came up.
http://www.scantips.com/simple.html
It goes into great detail on lots of different subjects.
Cita
posted on 19/7/04 at 03:06 PM Reply With Quote
Crbrlfrost,the pictured sketch was an early drawing and i intended tu use a sway bar.The comments, especially from Rorty,made me think again and perhaps it's not such a bad idea to go for a live axle without a diff on such a light car.
It surely would simplify things but the monoshock idea would'nt work on this i think.Since i use a chain to drive the rear axle the suspension can be a simple craddle like construction on which the rear axle is bolted.This craddle can move up and down with only a slight variation in distance decrease towards the engine sprocket.A Panhard rod will keep things more or less centered.
Dont know if it work's but gonna give it a try anyhow.
New Topic New Reply
