New Topic New Reply
Author: Subject: Formula 27?
digiman
posted on 6/6/11 at 08:28 PM Reply With Quote
Formula 27?
Ok I have bought a car that is registered as a Formula 27 Clubman. However it does not have inboard springs and dampers, but are outboard. Does anyone know if this was an option, or a conversion job?
Many Thanks
designer
posted on 6/6/11 at 08:44 PM Reply With Quote
The original plans had inboard springs, maybe it's a later model.
andrew-theasby
posted on 6/6/11 at 09:13 PM Reply With Quote
YKC sold a formula 27 when i was looking to buy one, when they had their York factory. One of their models had outboard suspension but im not certain if it was the formula 27 or a locost, ill have a look and see if i have any more info anywhere.
posted on 7/6/11 at 10:41 AM Reply With Quote
I am not aware of it being an option; you sure it is formula 27 chassis? Just becasue it is described as one, does not mean it is. Can you post photo showing the front chassis.
pewe
posted on 7/6/11 at 10:52 AM Reply With Quote
As far as I know all F27s have inboard front suspension - that was their main difference from other marques.
What is the bonnet?
Certainly later ones have a one-piece bonnet with an intake just above the nose-cone section and a bulge running up to and into the scuttle.
As above pics would help.
If factory built there should be a build plate somewhere around the engine bay.
Marque is currently owned by Peter Allen at Image Sportscars.
HTH.
Cheers, Pewe
locoboy
posted on 7/6/11 at 12:56 PM Reply With Quote
This is my old F27 with inboard suspension and the early style bodywork.
vent
vent
F271
F271
Forum member 'gregf27' 's Formula 27 again with inboard suspension and the newer style bodywork.
GF27
GF27
Locoboy
digiman
posted on 7/6/11 at 08:37 PM Reply With Quote
Here you go:
Any suggestions?
jacko
posted on 7/6/11 at 08:46 PM Reply With Quote
Looks like a locost to me
alfas
posted on 12/7/11 at 05:25 PM Reply With Quote
enginebay pictrues would help to see if somebody cut the original inbord fixings, also i think, from first view, that it isnt a forumla27..likely to be "something" using a formula27 V5 to avoid sva/iva
adampage
posted on 13/7/11 at 02:05 PM Reply With Quote
Those wishbones....
Are Stuart Taylor, I'm sure they are. The way they have the 'lip' at the end of the bottom one is quite distinctive and exactly how mine was.
Or Aries Motorsport as they're now known.
That car's been advertised a few times over the years, it's a CBR1000 isn't it, so very short-geared? I remember years ago seeing it with a carbon-look body and removable rear lights on a separate panel, then I think someone did it up & gave it the new orange paint job and remarketed it.
Hope that helps
Ad
New Topic New Reply
