Author: Subject: any recommendations on IT helpdesk software
mads
posted on 23/7/12 at 11:43 AM Reply With Quote
Afternoon all,
Seeing as there are a few IT people on this forum, wondered if anyone can recommend some opensource php/mysql helpdesk software?
Need it for my department to basically log calls of work requested, how long it took, requestor, any problems etc. Don't want anything too fancy but need something powerful enough to be able to generate reports to show how much work is getting done as well as flag areas where we could do some training to help users and reduce requests.
In terms of number of users, there will be 3 higher level and then approx 120 standard users.
Have looked on the following link but having never used any of them was wondering if anyone had recommendations: http://www.opensourcehelpdesklist.com/
Thanks,
mads
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
andy350z
posted on 23/7/12 at 11:47 AM Reply With Quote
My wife's company uses Footprints from Numara.
She has been really happy with it.
If want any more info, PM and I'll send you her email address
http://www.numarasoftware.co.uk/footprints/
jaik
posted on 23/7/12 at 11:51 AM Reply With Quote
Give Zendesk a look.
mads
posted on 23/7/12 at 11:53 AM Reply With Quote
thanks both. forgot to mention it needs to be free
Pdlewis
posted on 23/7/12 at 12:04 PM Reply With Quote
I used mantis a while ago, wasn't the prettiest but it worked, looks like the UI may have had an overhall
Mantis
Build Photo Album
Updated 05/02/2009
RichardK
posted on 23/7/12 at 01:04 PM Reply With Quote
Spice works is very good and free and can keep a track on software audits on installed software.
http://www.spiceworks.com/
Rich
[Edited on 23/7/12 by RichardK]
Gallery updated 11/01/2011
awinter
posted on 23/7/12 at 02:17 PM Reply With Quote
Spiceworks +1
Also does inventory and lots more. Free !!
Agriv8
posted on 23/7/12 at 03:19 PM Reply With Quote
We use ManageEngine SD+ its not free though I think you can have a free demo to see if it works.
We have similar numbers to you and are fully operational it scan hardware for inventory. let users log fults online via email. logs soloutions
after 2 years using it we cant run without it cant recomend it enough really never looked at free versions but think it a Couple off K a year for 10 Technicians
ATB Agriv8
Jed
posted on 23/7/12 at 04:58 PM Reply With Quote
If you want something that is reasonably simple to configure and use then try OneOrZero - http://www.oneorzero.com/ and the link to the open source helpdesk software is http://www.oneorzero.com/smforum/index.php?topic=6192.0
That is the software that I used at a previous employer and we used that for 3 years, the last year of which was sent trying to find a free helpdesk / change management / cmdb system. In the end we went for RT but that requires quite a bit of configuration to get it to do stuff so wouldn't recommend it to someone unless they're really into tweaking perl scripts etc.
The SpiceWorks software works well but the advertising and other stuff cluttering up the screens put me off plus the fact that data goes back to Spiceworks. Depends of your business sector as to whether that is acceptable, so do check the Spiceworks T&Cs and data gathering policy.
Dangle_kt
posted on 23/7/12 at 05:06 PM Reply With Quote
I used this at the last place I was - worked ok.
There is a free version, I think we used the mid range
http://www.manageengine.com/products/service-desk/
ironside
posted on 24/7/12 at 12:12 PM Reply With Quote
RT (Request Tracker) is the daddy of the free/open source ones:
http://bestpractical.com/rt/
mads
posted on 25/7/12 at 09:27 PM Reply With Quote
Thanks for all the replies everyone. I like the look of spiceworks and RT so will take a closer look at each.
Acc8braman
posted on 21/8/12 at 09:02 AM Reply With Quote
I use OTRS
