Author: Subject: Advantages of pannels on the bottom of your car ?
greavesy7
posted on 4/11/14 at 10:00 PM Reply With Quote
I'm just in the middle of a n engine transplant on my gbs zero from a pinto to a zx9r engine. I have the chance to pannel off the bottom of my car as the engine does not stick past the chassi . What are the advantage of this if any.
snapper
posted on 4/11/14 at 10:11 PM Reply With Quote
Alledgely a smooth airflow under the car
However you need a rear diffuser to get any downforce
Disadvantage is that the hot air from the radiator has no where to go
IMHO not worth it
I eat to survive
I drink to forget
greavesy7
posted on 4/11/14 at 10:39 PM Reply With Quote
I have got a diffuser but I kind of agree that it's prob not woth it
mark chandler
posted on 4/11/14 at 11:13 PM Reply With Quote
Top end and economy, leave it open like under the axle fuel tank and you have added two parachutes under your car.
jwhatley
posted on 4/11/14 at 11:15 PM Reply With Quote
I have one, I noticed a difference in cornering at high speeds on track.
Cooling isn't an issue with mine although I have wide side pods.
Big up side for me is the fact the engine bay stays a lot cleaner!
Mine is fixed on rivnuts, so removing it is a 5 minute job.
IMO, it's worth it for the cost of a bit of aluminium.
r1_pete
posted on 5/11/14 at 08:05 AM Reply With Quote
Many if not most production cars have under trays fitted now, even my L200 pickup, so there must be a benefit, I'd guess in production car use its mainly for economy.
If you had some rear facing louvres punched it could help with under bonnet airflow and cooling.
Doctor Derek Doctors
posted on 5/11/14 at 08:29 AM Reply With Quote
Combined with a diffuser mine creates a large and noticeable amount of downforce, it also acts as a guard when rubbing over kerbs and it's nice to have a lovely clean engine bay even after a wet Trackday or spinning it through the gravel. As above mines on rivnuts so 5 mins with an Allen key has the whole underside removed for access.
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
Smoking Frog
posted on 5/11/14 at 09:51 AM Reply With Quote
Increase chassis rigidity? Not quite the same benefit as fitting the back to flat-pack furniture but I'm sure it will bring something to the party.
mark chandler
posted on 5/11/14 at 11:04 AM Reply With Quote
It's all about the little changes once you have made your car.
Lose 5% weight
Lose 5% drag with underfloor sheeting back to front
Gain 5% more power
It's adds up and is cumulative so above is really 16.5% in total
posted on 5/11/14 at 11:55 AM Reply With Quote
Forgot to mention that, mine is a single piece of 5251 that runs the entire length of the car and is bolted on at all the node points.
www.t89.co.uk
callan@t89.co.uk
Slimy38
posted on 5/11/14 at 12:37 PM Reply With Quote
I suspect it's mostly for decoration so the average Joe doesn't see all the 'horrible greasy bits' when they're in a showroom wanting to buy their new car. Same under the bonnet, I can't remember the last time I saw an engine rather than covers and panels covering everything.
Mr Whippy
posted on 5/11/14 at 01:26 PM Reply With Quote
A lot of covers are acoustic too and help cut out high frequency chatter like tappets and diesel rattle.
I left of the bottom engine skirt of the wife’s cmax tdi and it was quite noticeably louder. Even the rubber seal under the back of the bonnet stops a surprising amount of noise, I take that off in the winter on my bluebird to let hot air from the engine flow over the windscreen to stop the wipers freezing up.
posted on 5/11/14 at 02:04 PM Reply With Quote
Tin top engine covers are there primarily for sound deadening. The engine under trays are there for aerodynamics to aid fuel economy. If you look under a modern tin top the manufacturer's go to quite a lot of trouble to smooth the airflow under the vehicle. As Mark comments, it's the cumulative effect of small changes that make the difference.
Ivan
posted on 6/11/14 at 02:09 PM Reply With Quote
Have read of this - quiet informative.
http://www.autospeed.com/cms/article.html?&A=2159
