Author: Subject: Rear Mounted Starter Type 9 Bellhousing
obr_technology
posted on 19/2/15 at 07:21 PM Reply With Quote
Hi All,
Does anyone know of an off the shelf type 9 bellhousing which enables the starter motor to be mounted on the bellhousing side rather than the engine side of the flywheel?
It's for a V8 project, where the four cyclinder and V6 traditional ford bellhousings make the starter clash with my cylinder barrels.
If I had the money I'd get a custom bellhousing made, but I just don't sadly so will end up trying to find a workaround using the four cylinder housing which I already have.
Any help would be much appreciated.
austin man
posted on 19/2/15 at 10:53 PM Reply With Quote
would need to watch which way the starter will crank the engine over, I have seen the bell housing modifies and have the starter housing moved to the opposite side, the guy who did it was a coded welder he fitted a type nine to a midget engine and modified the bell housing to suit
obr_technology
posted on 8/3/15 at 07:42 PM Reply With Quote
Thanks, yeah was thinking that the starter would need sorting.
As you say I think I'm going to need to make up accustom one.
