New Topic New Reply
Author: Subject: Haynes chassis build cost?
posted on 4/1/16 at 12:06 PM Reply With Quote
I'm sure there are many answers depending on how you spec it, but based on buying, cutting and welding yourself, what sort of money does it cost to build a Haynes roadster chassis?
I have no option to drive for most of 2016 and aside from a 205 GTI project I have some time spare to build another car so am looking at cost options.
Talon Motorsport
posted on 4/1/16 at 01:11 PM Reply With Quote
Assuming you have already have a hacksaw, grinder, welder then tube materials are £90-120 for 25x25x1.5mm and 20x20x1.5mm ERW with or with out the delivery, buy a 150x3mm flat and go scrap bin raiding for the 50x5mm flat, buy the suspension brackets don't bother making them.
Basic chassis including a steel floor should not be more than £300-350.
[Edited on 4/1/16 by Talon Motorsport]
posted on 4/1/16 at 01:14 PM Reply With Quote
I have tools to cut and shape and a welder and a local steel stockist to help.
Useful info - thanks!
posted on 4/1/16 at 01:23 PM Reply With Quote
Negotiate the steel based on weight if you can.
hizzi
posted on 4/1/16 at 02:08 PM Reply With Quote
i bought the chassis as a flat pack kit costing £350 so to buy the raw steel and cut yourself should e a chunk less, plus steel is cheaper now than last march
topcat2vin
posted on 20/1/17 at 06:43 PM Reply With Quote
Chassis Steel Price
Are these prices still about right for the chassis steel. £300-350 as above or has the steel price changed much. Also, building a chassis or using a flat pack kit is there much tolerance in the joints? (i.e. if there is a small gap between the steel before welding is there any issues with bodywork etc.)
Talon Motorsport
posted on 20/1/17 at 11:06 PM Reply With Quote
Prices pretty much the same.
Ugg10
posted on 21/1/17 at 08:14 AM Reply With Quote
If I was going to build from scratch it would be a midlana, easier engine install etc, unfortunately there are no flat pack for that available afaik.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
New Topic New Reply
