Author: Subject: Tin top : Clutch judder
tegwin
posted on 21/9/16 at 11:53 AM Reply With Quote
I am getting quite a lot of "judder" around the bite point on my little polo. Seems to be getting worse to the point where the whole car shakes if the clutch and RPM are at specific positions... the clutch doesn't slip on normal driving... Is this a clutch wear issue or could it be something else? Worn flywheel etc?
Im guessing that I am going to have to change the clutch but wanted to be sure there isn't something else at play here?
www.verticalhorizonsmedia.tv
SteveRST
posted on 21/9/16 at 12:15 PM Reply With Quote
I finding the same thing on my MX5 around the bite point. Will keep an eye on the replies to this topic.
adithorp
posted on 21/9/16 at 12:21 PM Reply With Quote
Most likely causes are oil/fluid contamination of the driven plate, cracked/distorted pressure plate spring/diaphragm, faulty release bearing. A worn dual-mass flywheel (if it has one) is a possibility though they usually rattle rather than judder. A cracked or warped flywheel could cause it but it rare.
Either way the box has to come off to change the clutch and find the cause.
[Edited on 21/9/16 by adithorp]
http://jpsc.org.uk/forum/
tegwin
posted on 21/9/16 at 12:23 PM Reply With Quote
Hmm, I guess a leaking seal on the crank or input shaft could cause contamination?! I know i can get the box out, gravity makes getting it back in again a little harder!
adithorp
posted on 21/9/16 at 01:03 PM Reply With Quote
A cracked diapragn spring (or worn fingers) is the most likely these days. Look for any uneven fingers on the spring before unbolting the cover. Oil less so now as seals have got better and if it was that you'd see some oil aroung the bellhousind the engine face.
posted on 21/9/16 at 03:07 PM Reply With Quote
All of the above, a distorted driven plate is another possibility but check the engine mounts and also the front suspension bushes and ball joints before stripping the gearbox out.
ian locostzx9rc2
posted on 21/9/16 at 05:17 PM Reply With Quote
What age is the polo as early ones suffer from pedal boxes and bulkheads cracking aswell .
posted on 21/9/16 at 07:19 PM Reply With Quote
Menories of this being more or less the norm on Hillman Avengers
