Author: Subject: Rim sections for 13" Image wheels
deanspoors
posted on 23/1/17 at 08:54 AM Reply With Quote
Just a thought, any rim sections out there inner/outer.
Dean
CNHSS1
posted on 25/1/17 at 09:21 PM Reply With Quote
What sizes?
deanspoors
posted on 26/1/17 at 12:14 AM Reply With Quote
Anything really. What have you got? I need some outer rims for one set of wheels and inner rims for another set I have.
Dean
CNHSS1
posted on 26/1/17 at 12:17 AM Reply With Quote
Defo got some spares, will check dims Friday evening or Saturday
CNHSS1
posted on 5/2/17 at 06:24 PM Reply With Quote
I have:-
7" inner x 2
6" outer x 3
3.5" outer x 2 both bent edges, will straighten but not pretty
1.125" outer x 2
1.5" outer x 2
4.5" inner x 1
Mix of revolution, Compomotive and force sections
Any use?
CNHSS1
posted on 5/2/17 at 10:11 PM Reply With Quote
2 x 6"outers gone, dinged 3.5" outers and the the 1 x 4.5 inner, rest still available
deanspoors
posted on 5/2/17 at 10:39 PM Reply With Quote
Hi, if the 7" inners are the same sizes as image, I would like them. Could you measure the PCD please and no. of bolts.
Thanks, Dean
CNHSS1
posted on 6/2/17 at 03:33 PM Reply With Quote
Yep will do tonight. Defo 18 hole but can't remember bolt hole PCD or centre bore, will let you know later
Cheers craig
CNHSS1
posted on 6/2/17 at 06:53 PM Reply With Quote
CNHSS1
posted on 6/2/17 at 06:54 PM Reply With Quote
I'd say about 268mm hole centre to hole centre
And centre bore of 256? Mm
deanspoors
posted on 6/2/17 at 09:59 PM Reply With Quote
Hi mate, had a measure up and I think they're going to be too tight towards the rear dampers mate unfortunately, the PCD does seem identical though FYI.
