<<  1    2  >>
Author: Subject: GTiR Plenum backplate in billet
jeffw
posted on 1/2/17 at 10:45 AM Reply With Quote
My new billet plenum backplate has arrived. Think it looks rather nice
[Edited on 1/2/17 by jeffw]
Dick
posted on 1/2/17 at 12:02 PM Reply With Quote
Looks very nice if I must say so myself
jeffw
posted on 1/2/17 at 12:11 PM Reply With Quote
Thanks to Dick
bi22le
posted on 1/2/17 at 12:49 PM Reply With Quote
Is this going to have trumpets going through as the inlet mouths are not turned.
I can see that you have rubber o rings to seal it so I cant work out how your are going to smooth the air flow into the ITBs.
Please read my ring story:
jeffw
posted on 1/2/17 at 12:55 PM Reply With Quote
19mm trumpets as before with the other backing plate
jeffw
posted on 1/2/17 at 01:15 PM Reply With Quote
although you don't actually need them with forced induction. A number of big power cars don't use trumpets in their plenums
Dick
posted on 1/2/17 at 03:38 PM Reply With Quote
The o ring are to seal the back plate to the throttle bodies as jeff and I both think we need to ensure that no boost pressure is lost, the bore of the plate is an exact fit to the throttle bodied so no step is present so its just like the throttle bodies are a bit longer, the trumpets are also and exact fit so its the trumpet length plus the plate thickness onto the original itb's. If you run your finger over the joints you can feel the joint but cant detect any step
CNHSS1
posted on 1/2/17 at 03:51 PM Reply With Quote
*cough* big tart Jeff *cough*
Craig
richardm6994
posted on 1/2/17 at 04:36 PM Reply With Quote
Very nice indeed jeff!
May I ask what depth you've gone for on the internal step to increase volume plenum?.
I think you've already seen my efforts on here and facebook (the blue charger on the silvertop zetec) and I went for a 16mm depth, but yet to see what the rolling road results are like.
I'm currently planning another one now for an ST170 engine in a GBS zero. This time however I'll be machining with bell mouthed / trumpet shaped inlet holes.
jeffw
posted on 1/2/17 at 04:42 PM Reply With Quote
Craig
I'll be having words later ...
jeffw
posted on 1/2/17 at 04:44 PM Reply With Quote
Your efforts are always interesting and well done. The step is 10mm from memory but could be much larger but at the expense of machining a very large billet to get the increase depth.
richardm6994
posted on 1/2/17 at 05:02 PM Reply With Quote
Thanks Jeff,
The billet isn't too expensive, I think the piece I used on the blue charger was about £20 and the thicker one (to allow for the bell mouths) I'll be using for the ST engine will be about £30........only downside to these is loads of bl00dy swarf everywhere!!
They polish up nice though!
CNHSS1
posted on 1/2/17 at 05:55 PM Reply With Quote
Anything billet is worth 10 pit-pose points and .2s on the track for sure
jeffw
posted on 1/2/17 at 06:22 PM Reply With Quote
lol
SPYDER
posted on 1/2/17 at 07:44 PM Reply With Quote
Nice work. I'd have put pockets in between the holes on the back for lightening. And even more bling! I might even have tried machining integral bellmouths!
I did 20 years in CNC machining but haven't done any for a while. Its highly satisfying turning a blank into something like your plenum. I've even considered buying a small machine for the garage.
Now where are those roller barrel throttle sketches...?
richardm6994
posted on 1/2/17 at 08:18 PM Reply With Quote
CNC = LOL &#128512;
The trick is machining stuff the old fashion way and people thinking it's been done by CNC.
For the intergrated bell mouths I'm doing on this latest gtir back plate, I'm machining a bespoke cutter to make sure the bells are all the same shape and size. This in itself is hours of work but a lot more satisfying than g-code (which I have to do from time to time at work) or catia.
jeffw
posted on 1/2/17 at 08:38 PM Reply With Quote
Much as I enjoy a bit of CNC billet it is about going faster and not really about looking good, although the new body kit will do that (and shocks/wheels !)
jambojeef
posted on 1/2/17 at 09:40 PM Reply With Quote
http://www.profblairandassociates.com/pdfs/RET_Bellmouth_Sept.pdf
posted on 2/2/17 at 11:04 AM Reply With Quote
True - clearing up the swarf can be hard work!
SPYDER
posted on 2/2/17 at 04:09 PM Reply With Quote
In my last job we machined some "swing wing" hinge prototypes from the largest ally billets I have ever encountered.
The largest was about five feet by three feet by about 18 inches. We had to modify the bed with indexing pins so that we could move the billet along.
Ninety five percent of it was reduced to swarf. This was on an open machine too.
jeffw
posted on 4/2/17 at 12:18 PM Reply With Quote
On the car...
gaz_gaz
posted on 4/2/17 at 01:53 PM Reply With Quote
Very nice..
Did you build the car from scratch Jeff or did you buy and modify modify modify?
jeffw
posted on 4/2/17 at 03:02 PM Reply With Quote
Bought it about 10 years ago with a Silver Top on carbs....changed a bit since then
richardm6994
posted on 13/4/17 at 09:44 AM Reply With Quote
Here is my home made effort now it's finished. Started out as a 30mm thick ali plate.
The bell mouths have turned out alright as well.
jeffw
posted on 13/4/17 at 09:54 AM Reply With Quote
That's cool as well. Nice job.
<<  1    2  >>
