<<  1    2  >>
New Topic New Reply
Author: Subject: exoskelital chassis
lincsandy
posted on 19/10/17 at 02:59 PM Reply With Quote
Thanks for that! lots of information on using the st170 ecu.
I wanted to use the original ecu as I intend to run the engine as ford intended and won't be going for power upgrades as the car should be more than quick enough for me plus I have the focus loom so don't see the point of spending money on a aftermarket loom and ecu.
big_wasa
posted on 19/10/17 at 05:15 PM Reply With Quote
You did well to find an st around here. I want one from a track day car.
They turbo well
lincsandy
posted on 19/10/17 at 05:38 PM Reply With Quote
I had to travel 150 miles to get it, not from round here.
What's needed to turbo the st170 engine then? Think it would be a bit too lively in a rocket maybe.
big_wasa
posted on 19/10/17 at 06:03 PM Reply With Quote
You use the st170 bottem end to give you stronger pistons and rods. The black top, top end to get rid of the vvt and a thicker head gasket to get the compression down. This is regarded as a reliable 350bhp capable lump.
Mine above is running on Oem Focus Rs Ecu. 215 in standard tune. 250 ish with a remap, 300 with parts and more boost.
How much rust did your donor have ?
[Edited on 19/10/17 by big_wasa]
lincsandy
posted on 19/10/17 at 06:15 PM Reply With Quote
The suspension is fairly corroded, rust underneath the car and the sump needs changing as it's very bad.
It needed steering rack for Mot and has done a shade over 100k.
I shall be removing engine and box at weekend. Then the wiring loom.
big_wasa
posted on 19/10/17 at 06:20 PM Reply With Quote
The sump is standard on these because the cat is so close to the sump.
lincsandy
posted on 26/1/18 at 11:50 PM Reply With Quote
Bit of an update.
been busy with work before Christmas so haven't finished stripping my st170 yet, then my kit wasn't ready until 2 weeks before Xmas.
so Its been in the shed for nearly a month.
I have got the chassis cleaned and removed most of the small weld spatter.
I have sprayed it with 2k etch primer and today 2 coats of 2k primer.
I am not new to spraying but spraying a rocket chassis is a real test, I've got 2 small runs in the primer that will flat out but the top coat needs to go on perfect.
before the top coat goes on I am going to make a support for each end to allow me to tilt the chassis on its side.
907
posted on 27/1/18 at 09:41 AM Reply With Quote
Quote:- "Before the top coat goes on I am going to make a support for each end to allow me to tilt the chassis on its side."
Basting ladle, spray gun, same principle.
[Edited on 27/1/18 by 907]
lincsandy
posted on 27/1/18 at 12:42 PM Reply With Quote
That would be good it would bake the paint as well lol.
<<  1    2  >>
New Topic New Reply
