New Topic New Reply
Author: Subject: Roll Cage continued
chris_smith
posted on 4/3/17 at 06:46 PM Reply With Quote
Roll Cage continued
So a few weeks ago I was looking for someone to supply a flat pack roll cage - See this thread - and eventually went back to Tube bender, and tweaked the quote to just supply and bending with me collecting, a few emails back and forth, I must point out that Tom @ Tubender is extremely quick at responding, and really is processional in his approach to the customers needs and does want to help where he can to provide a great service to the customer.
all in all I was quoted £300 for supply and bending
I collected within 7 days of deposit being transferred and the quality is exceptional.
if anyone needs a cage, roll bar etc then do try Tom fully recommended
its taken me a few weeks to get round to fitting but here are the fitted pictures from today -
cage 2
cage 2
cage 4
cage 4
cage 5
cage 5
cage 6
cage 6
cage 8
cage 8
cage 9
cage 9
AdrianH
posted on 5/3/17 at 01:09 AM Reply With Quote
Hi Chris, I am wondering if you are planning on running the car in any MSA type events?
I think you could have an issue with the front roll tube/bar due to the double kink/dog leg.
If just for road then should not be an issue, hope I am wrong so you can if you do want to use it for any sprints or hill climbs.
Adrian
[Edited on 5-3-17 by AdrianH]
Why do I have to make the tools to finish the job? More time then money.
loggyboy
posted on 5/3/17 at 09:13 AM Reply With Quote
No you are right, the double kink isnt blue book compliant so this would need to be a road only car.
Mistral Motorsport
mark chandler
posted on 5/3/17 at 12:38 PM Reply With Quote
Sprints and hill climbs you just need the rear hoop.
My front hoop did not comply so I removed it, I am not sure if they look at the cage as a whole when tagging I played it safe with the rules, I am sure my front hoop offered more protection
You still need rear stays and probally a rear diagonal although with a small engine even this can be ignored.
[Edited on 5/3/17 by mark chandler]
AdrianH
posted on 5/3/17 at 01:57 PM Reply With Quote
Hi Mark
That is really what prompted me to make the comment. On mine I only have the rear roll bar and it was OK, with diagonal and back stays for both sprint and hill climb, at one of the meets a car I believe did not pass scrutineering because it had the front bar with the dog leg even though the car only needed the rear section it seemed to be treated as a whole unit, as in part of it was not compliant therefore the car was not.
It did seem a bit extreme at the time.
I note that unless road going one also needs Hans now.
Chris may only be using it as a road car anyway so my warning may not be required, I guess it should still be OK on things like track days.
Adrian
chris_smith
posted on 5/3/17 at 05:53 PM Reply With Quote
Thanks for the input/info guys, I'm likely only to be using it for road use, it now has back stays, and will have a cross member where I'll have seatbelt mountings, it may be used for track days but unlikely to be used for anything more competitive than that
AdrianH
posted on 5/3/17 at 08:22 PM Reply With Quote
Hi Chris, how is it progressing?
Sorry if my post was a bit off putting but thought it worth passing on the info.
Adrian
gary gsx
posted on 7/3/17 at 06:52 PM Reply With Quote
Hi Chris
Looking good, are you using mx5 column and wheel? What sort of room have you got with legs etc and I guess that's a haynes chassis?
Ta Gary
chris_smith
posted on 7/3/17 at 07:40 PM Reply With Quote
I'm using Mx5 column and wheel, haven't got seats as of yet but have mocked up the seating position and looks to be pretty roomy in comparison to my old Stuart taylor
New Topic New Reply
