Westfield Complete running kit car engine 269hp Zetec turbo engine, exhaust, new radiator, charge cooler, ecu, loom, crank and bearings done 2017 for sale £2200
Still for sale Cost me over £8000.
Bought in Sept 2015 visited for reduce horse power to improve handling and power delivery
Changed the turbo over winter done 4 track days since
This car is mega fast with this engine and it will need you to take it steady.
Visited Bailey performance to look it over in March
Runs fine still in car so can be heard running
I'm moving to n.a to start racing
Comes with everything you need to get her running
Engine
Td04 turbo
Manifold
All Pipework
Exhaust
Wiring loom still connected
Mega squirt 2
Mega squirt 2 Bluetooth
Expansion tank alli
New charge cooler and radiator
Recent spark plug replacement
New alternator in January
More detail below from original build
Overall spec;
Engine is a Ford Mondeo zetec E bottom end fitted with forged pistons, HD bearings, new HP oil pump, new water pump. The head is a new (not recon)
Focus blacktop fitted with Piper performance valve springs.
Raceline sump
The induction is a custom made system based on a Jenvey inlet manifold, large plenum with large throttle body. 625cc Siemans Daka injectors.
Bailey dump valve.
Custom charge cooler with own separate water system, radiators mounted in front of engine radiator, separate water pump (Focus RS) and header tank.
Turbo is a Subaru Impreza TD04L on a Focus exhaust manifold, custom exhaust system, currently running 18PSI of boost.
Engine management is MS2, with boost control, MSD coilpack and leads. Launch control via dash mounted switch.
Fuel system is new Bosch 044 GRP A cosworth pump, large fuel filter, Lucas fuel pressure regulator.
£2200.
David Johnson
