New Topic New Reply
Author: Subject: Questions about build....
TurboLocost
posted on 2/11/18 at 08:57 PM Reply With Quote
I'm going to do a rear engine build as you probably know
But I have a few questions.....
Firstly, I'm planning on building a roll cage sort of setup, but using a windscreen area roll hoop and then twin parallel tube to the rear roll bar, so it's still easy to get in (with a few braces
If I sva without windscreen can I then add one later on?
Planning on using a defender windscreen and cutting it down (although I do have a series land rover windscreen and surround I could modify to make it smaller
And will plan to have a soft top and doors as such for wet weather, what's best approach to that and it be waterproof?
gremlin1234
posted on 2/11/18 at 09:34 PM Reply With Quote
Originally posted by TurboLocostIf I sva without windscreen can I then add one later on?
yes, but if it looks like it should be there and is 'missing' at iva, they may fail it.
current IVA manual at
https://www.gov.uk/government/publications/iva-manual-for-vehicle-category-m1
New Topic New Reply
