Author: Subject: Zetec engine mounts
madrallysport
posted on 26/10/19 at 07:19 PM Reply With Quote
Zetec engine mounts
Has any body any Zetec engine mounts they donít need, itís for an ST170 so as far as I know same as a black top Zetec
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
loggyboy
posted on 26/10/19 at 08:40 PM Reply With Quote
Will depend on car its going into. Considered making them?
big_wasa
posted on 27/10/19 at 03:51 PM Reply With Quote
The st block is not identical to the Bt.There is a couple of holes missing on the N/s and one on the O/s.
There are a couple of holes that are drilled for locating dowls so the thread doesnít start until a few mm down.
