Author: Subject: mains to DC12v 20a
pigeondave
posted on 19/3/20 at 01:41 PM Reply With Quote
mains to DC12v 20a
Hi all,
I'm looking for a mains to 12v 20a power supply.
Basically I'd like a cigarette lighter socket in the garage/workshop.
Electrics always worry me, and a lot of the stuff online looks Chinese and of questionable quality.
Also not sure if i need 20A, i picked that as most sockets show 20A capability.
Doe's anyone have a link for something suitable?
Grimsdale
posted on 19/3/20 at 02:02 PM Reply With Quote
an old computer psu should be able to supply that, you just need to connect the two wires in the main multiplug to switch it on.
SJ
posted on 19/3/20 at 02:51 PM Reply With Quote
Old 12v car battery and a charger?
loggyboy
posted on 19/3/20 at 02:54 PM Reply With Quote
20a seems lots - whats it for?
Mistral Motorsport
pigeondave
posted on 19/3/20 at 03:03 PM Reply With Quote
I dunno, I just thought if they're rated for 20A why not have a 20A capability.
If going for less is easier and cheaper, i'll try that.
I like the computer PSU idea.
Really looking for something I can bundle up and put away, so was looking for a cheap (but well made) transformer block type thing.
Not favouring the battery thing as i'd like it easily portable.
Keep the ideas coming
posted on 19/3/20 at 03:18 PM Reply With Quote
These things work very well - I have several that supply power to my 3D printers.
ebay
The one very real hazard with these things is the exposed terminal strip at the back - both mains and output. Some form of rear enclosure is essential to keep everything safe - if you have access to a 3D printer then there's loads of designs available for a rear cover, but if metalworking's your thing then a folded metal rear cover would be fine. You do have to be sure that your wiring and earthing is safe and secure. I've used both methods...
[Edited on 19/3/20 by David Jenkins]
The older I get, the better I was...
cliftyhanger
posted on 19/3/20 at 03:26 PM Reply With Quote
20A is a lot.
Most new cars have a 10A or less supply as not used as fag lighters, but to power chargers and suchlike.
Have a think about what you plan to plug in, otherwise you will be over complicating things. I assume you are not planning on using an actual fag lighter?
HowardB
posted on 19/3/20 at 03:31 PM Reply With Quote
range up to 60A linky
not cheap but then they can be voltage controlled, current limited etc,
Howard
coyoteboy
posted on 19/3/20 at 05:31 PM Reply With Quote
I've always had a chopped up ATX power supply sat on my bench which supplies every voltage range I need. Cut the cables back, fit banana sockets, you have a nice reliable, stable PSU. You could even build it into the workbench and have it remoted underneath so only the sockets were visible.
Report your local potholes, it actually works!
jps
posted on 20/3/20 at 09:43 AM Reply With Quote
I bought one of these recently: https://www.ebay.co.uk/itm/12V-Air-Compressor-Tyre-Inflator-and-mains-power-supply-converter/152694505216
The pump died fairly quickly (after about 5 uses) but the power supply is powering a more susbstantial tyre inflator, which apparently has a peak amperage of more than the 10A this power supply is apparently good for.
I am tempted to buy one of those PSUs David has linked to though.
