New Topic New Reply
Author: Subject: Rear arch to chassis curved bar bit
Avoneer
posted on 12/3/06 at 04:29 PM Reply With Quote
Anyone got a good solution to this other than getting someone to bend a bit of 25mm square for me that matches the same profile of the arch?
Pat...
ned
posted on 12/3/06 at 04:38 PM Reply With Quote
get soe wings from stuart taylor? their wings are different and make up the curved bit for you - look for a pic to see what i mean! i think sideways dirt has some in his archive..
Ned.
beware, I've got yellow skin
Avoneer
posted on 12/3/06 at 04:52 PM Reply With Quote
Got some ST arches.
I've had to patch them up though as they were battered and they are now a lot heavier.
Also, don't think they would last long as a lot of folk put one hand on the arch when getting in and I wouldn't trust these.
Pat...
locoboy
posted on 12/3/06 at 04:57 PM Reply With Quote
Dont use 25mm square, use 25mm flat bar.
Dead easy to bend.
Locoboy
Avoneer
posted on 12/3/06 at 05:02 PM Reply With Quote
Nothing to bolt the arch to then.
Pat...
posted on 12/3/06 at 05:04 PM Reply With Quote
Been wondering about this bit I came up with a few possible soltuions
(1) as per Loco boy 25x2.5 flat strip hot bent.
(2) Tradditional use a wood (ash) frame and clad with alluminium sheet.
(3) Make a Grp mould up
posted on 12/3/06 at 05:06 PM Reply With Quote
Pat...
Weld in a steel panel (bit out an old PC case ?) and clad it with alloy.
DIY Si
posted on 12/3/06 at 05:11 PM Reply With Quote
Why not use angle? Cut V's in it to allow it to bend to the required shape. Then you've got all the bolt holes you'll need/want to put in.
Kev99
posted on 12/3/06 at 05:27 PM Reply With Quote
use flat bar and weld tags on (as angle ) where u need to bolt the arch on.
big_wasa
posted on 12/3/06 at 05:28 PM Reply With Quote
Thats What I have done.
I put to much heat in when seam welding it and it distorted a bit
How did painting the chassis with por15 go Pat ?
locoboy
posted on 12/3/06 at 05:55 PM Reply With Quote
Thats what i was meaning and intend to do
Locoboy
Avoneer
posted on 12/3/06 at 06:16 PM Reply With Quote
Flat and tabs is looking good at the moment.
Pat...
DIY Si
posted on 12/3/06 at 06:20 PM Reply With Quote
Forgive me if I'm wrong, but don't pedals see loads of force in emergency stop type situations? Surely you don't want these snapping at such a time?
zilspeed
posted on 12/3/06 at 06:29 PM Reply With Quote
Previous post deleted for fairly obvious reasons
Dale
posted on 12/3/06 at 07:10 PM Reply With Quote
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
New Topic New Reply
