Author: Subject: Bolt on shafts and subframe
mistergrumpy
posted on 31/12/06 at 06:54 PM Reply With Quote
Following on from my bargain thread. How do I get the driveshafts off the subframe? Is it simply a case of removing the torx/hex head bolts and removing one from the diff. cos they keep rounding and they're tighter than a Yorkshiremans wallet
pathfinder
posted on 31/12/06 at 06:58 PM Reply With Quote
Yup that’s all, they are tight little feckers, I soaked them in wd40 for a day and still needed to chisel them off!
posted on 31/12/06 at 07:21 PM Reply With Quote
Have a search of the archives, long history of removal problems with these little gits.
posted on 31/12/06 at 07:28 PM Reply With Quote
I can concur that they're a right PITA!!! Soaked them in WD40 for a few days but still no joy. Ended up grinding the heads off to release the shaft then using a combination of pliers and stud extractors on the resultant studs (didn't have a welder then for the weld-on-a-nut job) I managed to get them free....
posted on 31/12/06 at 08:30 PM Reply With Quote
Cut them off and replace with new bolts, has been covered loads of times.
stevec
posted on 31/12/06 at 10:12 PM Reply With Quote
Give each one a sharp blow on the head, this will shock them and they will come undone easier.
Steve.
givemethebighammer
posted on 31/12/06 at 10:28 PM Reply With Quote
impact wrench shifted all of mine. Only managed to break one halfords professional T40 bit (which they replaced no questions asked.
smdl
posted on 31/12/06 at 10:43 PM Reply With Quote
Broke two bits without moving a single one. Finally ground off half of the heads, leaving a semi-circle with one big, flat side, and then used a hammer and chisel on the top edge of the flat in order to spin them loose in a counter-clockwise manner. As soon as they were broken loose, I could remove each one with just my fingers.
Hope this helps.
Shaun
[Edited on 31/12/06 by smdl]
mistergrumpy
posted on 1/1/07 at 12:18 AM Reply With Quote
Ah, so I need to show them a bit of loving eh. Tried a few searches but unless you get the correct words (and english isn't my best language despite being born here and living here all my life!) you're on a bit of a loser. This search button seems a bit tempramental compared with some.It'll be computery things no doubt.
