Author: Subject: paint or powder coat roll bar ?
givemethebighammer
posted on 13/11/03 at 11:19 PM Reply With Quote
I want something thick and tough (too cover up some of my untidy fabrication and look good for a long while).
pref. satin black coloured
any ideas
Hugh Paterson
posted on 13/11/03 at 11:27 PM Reply With Quote
Assuming its fitted to the chassis powder coat the lot, but from experience and looks the whole chassis needs to be done, ONLY after you have completed all the fabrication/welding. If u may have a need to change something or add more welding, flash paint with primer which can be easily rubbed back or shot blasted prior to re coating at the final finish stage.
Shug.
givemethebighammer
posted on 13/11/03 at 11:38 PM Reply With Quote
I have fabricated my roll bar to bolt on to the chassis so taking it somewhere for shotblasting/ painting / coating etc is not an issue.
Just wondered what other people had done. Plus people say that power coat is brittle and chips easily ?
posted on 14/11/03 at 12:54 AM Reply With Quote
OR...
blueshift
posted on 14/11/03 at 01:21 AM Reply With Quote
Odd to hear you say powder coat is brittle and chips.. I was under the impression it gave a plasticy coating, and is generally considered much tougher and tolerant to chemical and environmental abuse than painting.
Please note I may be talking complete arse.
madforfishing
posted on 14/11/03 at 07:00 AM Reply With Quote
Hellfire, where and how much did it cost to get your roll bar chromed?
Looks the business, by the way.
ChrisW
posted on 14/11/03 at 09:06 AM Reply With Quote
My chassis has been powder coated. Wish I hadn't bothered - it's covered in chips and scratches and is really obvious where I've had to touch it up with paint.
Chris
My gaff my rules
Ben_Copeland
posted on 14/11/03 at 09:16 AM Reply With Quote
I'll be painting mine.
Not sure powder coating would cover much up. Nice thick coat of paint will tho
Ben
Locost Map on Google Maps
Enter Your Details Here
givemethebighammer
posted on 14/11/03 at 11:59 AM Reply With Quote
So what paint then the dreaded HAMMERITE or something else ?
Ben_Copeland
posted on 14/11/03 at 12:15 PM Reply With Quote
Do a search for "chassis paint"... loads of info will come up
Ben
RichyMkIndy
posted on 15/11/03 at 09:22 PM Reply With Quote
PAIINT it !
look at my chasis !
it really does look like its been powder coated
i used zinc primer and then top coat of hamerite stone chip paint
The stone chip paint comes in very large red/yellow cans , we used black, the paint is amazing looks so good, not gloss just nice and it has like a sort of plastically feel to it and it dries really fast the finish is soo good i prefer it to powder coating
painted the whole chassis in it !
its amazing stuff
givemethebighammer
posted on 16/11/03 at 04:46 PM Reply With Quote
Took a quick look
Looks good. Does it stay soft for weeks like normal hammerite. ? Also is the black more of a satin than a gloss ?
thanks
pbura
posted on 16/11/03 at 08:44 PM Reply With Quote
Looks really great, Rich!!
I've been thinking of semi-gloss for the chassis myself. Put it on with a brush, no marks, no fuss, and good-looking, too.
Pete
Pete
posted on 17/11/03 at 12:33 PM Reply With Quote
original question...
Roll Bar was chromed by a good friend together with front wishbones and lightbar for £90
I know I know - good price!
RichyMkIndy
posted on 17/11/03 at 03:00 PM Reply With Quote
this is what you guys want
ive added loads more details pictures so you can see the finish
dont forget to use Halfrods Zinc primer and not Zinc 182
http://www.motortraders.com/xcart/catalog/product_16902_Hammerite_Stone_Chip_600ml.html
[Edited on 17/11/03 by RichyMkIndy]
givemethebighammer
posted on 17/11/03 at 08:25 PM Reply With Quote
Does look good, did you brush or spray it on ?
also ad states:
Tough and durable.
• Remains flexible and will not crack or peel.
• Overpaintable with most top coats.
• Colours - Black, White, Grey.
remains flexible.... how flexible ?
[Edited on 17/11/03 by givemethebighammer]
Ben_Copeland
posted on 17/11/03 at 08:33 PM Reply With Quote
Its spray on... I've just bought a litre tin that i can spray with my airgun £6.99
Hammerite Stone Chip Shield
Ben
givemethebighammer
posted on 17/11/03 at 08:41 PM Reply With Quote
Take it that's spray on via compressor not aerosol type ?
compressor.....that was the next thing on my list.......
Ben_Copeland
posted on 17/11/03 at 08:45 PM Reply With Quote
you can get it in spray can too(no compressor needed!!!)... 600ml one for £5.99
Ben
RichyMkIndy
posted on 19/11/03 at 03:12 PM Reply With Quote
yeah i used spray
dont hand paint ur chassis its a joke.
plus dont use Zinc 182 use Halfrods Zinc primer spray
pbura
posted on 19/11/03 at 05:26 PM Reply With Quote
Originally posted by RichyMkIndydont hand paint ur chassis its a joke.
Yeah, you're right
Pete
mackie
posted on 19/11/03 at 06:02 PM Reply With Quote
Hand painting is less wasteful though.
I'm thinking of going the POR15 route but to do it properly it gets really expensive.
Degreaser (disolves rust too), metal prep, POR15, topcoat primer and POR15 topcoat = about £60 and only for 1l of paint. Still it should be indestructable once done.
Might be overkill really, just need something chip resistant that sticks really well.
locoboy
posted on 20/11/03 at 11:06 AM Reply With Quote
Have spent 3 full days in total sanding/grinding with the tool and undercoating the chassis, needs another undercoat and topcoat now!
my advice, get it shot blasted rather than use the tool! and spray it rather then brush it, the extra money compared to the time saved it well worth it.
Locoboy
greggors84
posted on 20/11/03 at 06:04 PM Reply With Quote
If thats £60 for 1 litre, its going to be pretty expensive. I have a feeling you are going to need quite abit more than 1 litre.
Chris
The Magnificent 7!
