Mk indyblade identify my rad
keljon - 10/9/16 at 01:18 PM
My rad is looking tired so want to replace it, can anyone help me identify what it's off?
It's approx 410 by 320, integral pressure cap with expansion tank coming off the neck.
Pipe connections top right and bottom left, hose connections are same size as the fireblade engine
[Edited on 10/9/16 by keljon]https://www.dropbox.com/s/i7lp1ozy2e8zl5m/Photo%20 10-09-2016%2C%2012%2038%2030.jpg?dl=0
Matt21 - 10/9/16 at 01:35 PM
I was going to say it's probably a mk1/2 escort one before you had uploaded the photo. It isn't.
But it would fit. That's what mine uses.
I got an alloy one from this place on ebay:
http://www.ebay.co.uk/usr/radiator_specialists?_trksid=p2057872.m2749.l2754
It was a tight fit, but doesn't half keep the temps down!
Check measurements first too. And you may need to chop off an modify the lower tapping point so it points up instead of back (I made mine fit without doing this, but it gets very tight!)
I don't have a clue what your one is. Doesn't look like the polo, escort or sierra
[Edited on 10/9/16 by Matt21]
keljon - 10/9/16 at 01:38 PM
I don't think it's an escort one which is why I was hoping someone could identify it and will just replace with a new one of the same rad
benchmark51 - 10/9/16 at 03:29 PM
I have just bought and used this one, cured my overheating problem. Size is similar, worth a look. Delivery very quick too.
3ROW ALUMINUM RADIATOR For 1992-2000 Honda CIVIC D15 D16 EK EG / INTEGRA DB DC
40inches - 10/9/16 at 05:48 PM
Used one of those for the Jag engine, a nice steady 80-85degrees. Mega value.
keljon - 11/9/16 at 07:32 AM
Great price, will get the nosecone off and have a proper measure up
