Help with me Nuts
kitcar007kev - 4/11/12 at 05:24 PM
Putting some breaks together and not to sure what the nuts are. i am gussing that the cut and notch in them are somthing to do with heat or locking and that the flat side should go aginst the break disk. Can aybody help?
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
ian locostzx9rc2 - 4/11/12 at 05:28 PM
Yes flat of nut to brake disc (locking nut)
kitcar007kev - 4/11/12 at 05:32 PM
[img][/img]
[Edited on 4/11/12 by kitcar007kev]
omega0684 - 4/11/12 at 07:00 PM
blingin ell, they look posh!
DIY Si - 5/11/12 at 09:55 AM
Which drive shaft ends are you using and how do you tighten the hub nut up? I'm doing something very similar on my Sprite and have been wandering how to best cut the CV cups off.
TAZZMAXX - 5/11/12 at 11:26 AM
It's called a Binx nut for anyone that might be interested.
kitcar007kev - 5/11/12 at 09:38 PM
cheers been doing some research on Binx nuts first time i have ever seen them
THE ALL METAL SELF LOCKING BINX NUT HAS INBUILT METHODS TO RESIST MOVEMENT THROUGH VIBRATION. THE BINX NUT HAS GROOVES CUT INTO THE FACE OF THE NUT, WITH A COMPRESSED TOP. THE ACTION OF THREADING ONTO A BOLT PUSHES AGAINST THE FACE OF THE NUT APPLYING AN OPPOSING FORCE COUNTERING THE THREAT POSED BY VIBRATION OR STRESS.
THE BINX NUT IS ALL METAL AND CAN THEREFORE BE CONFIDENTLY USED IN ENVIRONMENTS CONTAINING OIL, GREASE AND OTHER CONTAMINANTS.
THE BINX NUT CAN BE APPLIED MULTIPLE TIMES DUE TO THE TORQUE RESISTANCE BEEN MAINTAINED AFTER MANY APPLICATIONS
Not sure on the drive shafts as going to be getting them from zcars
www.zcars.org
the mini forum is quite good for info
www.theminiforum.co.uk
Kev
DIY Si - 6/11/12 at 07:31 PM
Do you have any more close up pics of your front hubs? They're the bits I'm interested in.
kitcar007kev - 6/11/12 at 08:26 PM
[img][/img]
[img][/img]
[img][/img]
[img][/img]
[img][/img]
Think they are machined down by zcars
DIY Si - 6/11/12 at 10:45 PM
Brilliant! Thanks for that. Is there a hex or flat on the back of the stub axle/driveshaft end? They look about as cut down as I was going to do mine, but I've been debating how to then tighten the hub nut up without the brakes.
