New Topic New Reply
Author: Subject: MK reverse box
J16
posted on 16/2/09 at 10:23 PM Reply With Quote
MK reverse box
Has anyone got any pics of the electric reverse that MK supply for a BEC? I'm thinking about getting one but it all depends on where it goes and if it'll fit.
Jk
eznfrank
posted on 16/2/09 at 10:34 PM Reply With Quote
I've not seen one but I believe there's a sprocket that goes between the diff and prop.
pgtips
posted on 17/2/09 at 08:04 AM Reply With Quote
Jk
Dint know MK makes one? Have you got any links, prices etc?
Coopz
posted on 17/2/09 at 08:38 AM Reply With Quote
I got one on order, think it was 300 quid. and yea they weld in a bracket in the central tunnel and it does go between the diff and prop
[Edited on 17/2/09 by Coopz]
Davey D
posted on 17/2/09 at 09:22 AM Reply With Quote
Ive got an electric reverse fitted to my MNR. i presume it will be the same idea as the MK one:
large gear between the prop, and Diff, then a motor mounted above it with a small gear on it. there is a lever near the dash that pulls a linkage to the motor, and makes the 2 gears mesh. i then press a button to power up the motor.
i have some pics at home that ill upload later so you can see
danny k
posted on 17/2/09 at 12:35 PM Reply With Quote
reverse
I have got a reverse fitted to my race car. If any one would like a look at how it's fitted or it works give MK a ring.The reverse kit is £350.
eddbaz
posted on 19/2/09 at 03:17 PM Reply With Quote
What is the total weight of it ?
pgtips
posted on 22/2/09 at 10:42 AM Reply With Quote
Morning.
Any more info on this?
J16
posted on 24/2/09 at 08:17 PM Reply With Quote
I contacted MK the other day regards the reverse. It uses an electric starter motor which sits under the diff at the back of the car and has an adapter which fits between the diff and the propshaft. The starter motor then drives the adapter, I think via a chain. Although still haven't been able to obtain any pics of it.
Hope that makes sense! I think it's a very good alternative to the costly quaife reverse box which sets you back at least £700 new and then requires a split propshaft.
New Topic New Reply
