New Topic New Reply
Author: Subject: oil filter / steering clash
StevenB
posted on 17/6/09 at 07:53 AM Reply With Quote
Have I made a daft mistake here?
2L silver top zetec in car for first time.
Lower section of Steering will not
fit by the oil filter engine mount.
Everything else look fine.
Any suggestions please?
Tried search - nothing obvious.
s
Steve Hignett
posted on 17/6/09 at 07:57 AM Reply With Quote
A picture would help, but is it hitting the Oil Filter or is it hitting the Engine Mount?
If it's hitting the engine mount (and you've fitted both correctly) then you will need to re-route your steering column round it. It should be relatively simple to do starting by lengthening the lower column slightly.
HTH
bilbo
posted on 17/6/09 at 08:15 AM Reply With Quote
If it's the oil filter in the way, could you fit a take-off plate and remote filter instead?
Build Diary: http://bills-locost.blogspot.com/
Web Site: http://locost.atspace.com
omega0684
posted on 17/6/09 at 08:34 AM Reply With Quote
fit a smaller filter? you would cuz have to change it a little more often.
theconrodkid
posted on 17/6/09 at 08:47 AM Reply With Quote
renault 5 turbo is the filter of choice
who cares who wins
pass the pork pies
big_wasa
posted on 17/6/09 at 08:48 AM Reply With Quote
If its only just fouling the filter you can get smaller filters.
Other way is to put another uj in the down link and suport it with a bearing.
posted on 17/6/09 at 08:50 AM Reply With Quote
I had the same prob, check my blog. I thought about using a smaller filter but was more happy using a remote filter head with the full size filter.
big_wasa
Be aware that the R5 filter may fit but it is not the same thread as the ford and there have been a few casses of them blowing of with the presure.
One is imperial the other metric.
That said I have got one on mine and it will stay ther untill the next oil change.
Dusty
posted on 17/6/09 at 09:15 AM Reply With Quote
I have run with a champion C104 for the last three years. Shorter than standard but not tiny like the R5. Changed every year. Done 15,000 miles including track and sprint without problems..
StevenB
posted on 17/6/09 at 09:21 AM Reply With Quote
I dont think a smaller filter will sort it.
It looks as if the filter mounting arm is in play.
Im using standard MK engine mounts with
the Zetec chassis set up. Does that not mean
all silver top owners have had the same issue?
This is taking the gloss off the high fiving and back slapping for getting the engine in.
zetec
posted on 17/6/09 at 09:37 AM Reply With Quote
I had one of the first MK with a zetec. I canted my engine over a few degree and this allows a full size mondeo filter. 8K miles and still going strong...That said I made the patterns for my mounts and MK fabricated them as they did not do zetec mounts at the time. I would look at the remote option if you cant sort it using the mounts.
posted on 17/6/09 at 09:39 AM Reply With Quote
Depends on which engine you have, mine was a silvertop 1.8 but now I have a very late blacktop the filter is in a different position.
There was some variance in the oil pump between different capacities and years.
davred
posted on 17/6/09 at 09:57 AM Reply With Quote
ZETEC OIL FILTER
USE A COOPERS Z107 O/D 80 THREAD 3/4X16UNF HEIGHT 60 ANTIDRAIN YES PRV YES PRV SETTINGS 11-16 HTH DAVID
martin1973
posted on 17/6/09 at 10:00 AM Reply With Quote
the filter you want is reno 4 GTL
903cc
reno 5 will blow off as the thread size is incorrect its 20mm thread AND YOU NEED 3/4
works fine you just need to change it more regular.
martin
big_wasa
posted on 17/6/09 at 12:38 PM Reply With Quote
Also the oil pump has a differant angle on the 1.8.
theconrodkid
posted on 17/6/09 at 01:42 PM Reply With Quote
i know a couple of people that have used this filter(me included) and never had one drop off,i cant believe the ford mounting is not metric
who cares who wins
pass the pork pies
whitestu
posted on 17/6/09 at 03:57 PM Reply With Quote
No problems with mine in the past 18 months, though mine is a blacktop.
Oil pressure is 100psi when cold, and has been tracked without any problems.
Stu
DavidW
posted on 17/6/09 at 05:30 PM Reply With Quote
I've just gone through this on mine (with Coozers old engine).
The smaller filters still wouldn't fit past the steering so I ended up re-making the MK mounts to move the engine slightly of centre and then fitting a remote filter (although the take off for this is the same as one of the smaller filter).
The carbs are off at the moment so I'll pop out and get a photo after the kids are in bed.
StevenB
posted on 17/6/09 at 09:01 PM Reply With Quote
Im not sure slightly off centre would do it.
I will get a few pics myself.
s
DavidW
posted on 17/6/09 at 09:11 PM Reply With Quote
Hope this helps?
Zetec Remote Filter
Zetec Remote Filter
StevenB
posted on 17/6/09 at 11:15 PM Reply With Quote
A few pictures of the displacment of the steering section. Rescued attachment Dscf2467 sm.jpg
StevenB
posted on 17/6/09 at 11:18 PM Reply With Quote
The vertical offset looks abit much to be over come with tilting the engine.
I have standard Zetec engine mounts and
an MK exhaust. So tilting is out as it will prevent
the exhaust exiting under the main top chassis rail.
From the looks of it moving across looks out too.
New Topic New Reply
