Author: Subject: Puter Died RIP. Which OS to load.
jollygreengiant
posted on 16/3/11 at 06:55 PM Reply With Quote
Well it seems, that again after 3 years off running (24/7, that is),my 'puter has died again. It switched itself off while I was sleeping. I tried turning it on but it would not go past POST. So I took the covers off to see if anything loose or blown, but no. So when I put the covers back on and plugged it in again it would not even get to post. Power is there but nobody is home.
So time for a new puter, this time though I am going to dual boot it and run one of the linux types instead of windoze. I know its been covered before but which will be the easiest and best for a puter Philistine like my self to use.
Your suggestions please.
Ta Very muchly.
posted on 16/3/11 at 07:06 PM Reply With Quote
I'd recommend Linux Mint - minimum amount of faffing about, and tends to run straight from installation without extra 'adjustment'.
It also comes with most of the bits & bobs needed to use the PC, e.g. word processor, spreadsheet, etc. (Open Office)
balidey
posted on 16/3/11 at 07:09 PM Reply With Quote
I've been using Ubuntu for past couple of years. Manages to do everything I wanted to do, even wife and kids can manage it
Dutch bears have terrible skin due to their clogged paws
posted on 16/3/11 at 07:13 PM Reply With Quote
Note: Linux Mint is Ubuntu with extra bits added. Both are top-quality systems, and both are easy to use.
zilspeed
This here laptop has had Kubuntu on it for about 3 years now.
Never ever a single issue.
It just works.
ChrisL
posted on 16/3/11 at 07:39 PM Reply With Quote
OSX, best linux flavour there is! Failing that Fedora Core or Centos, depends what you want to do with it.
If you want to explore the option of OSX have a look at http://tonymacx86.blogspot.com/2010/04/iboot-multibeast-install-mac-os-x-on.html
cd.thomson
posted on 16/3/11 at 07:46 PM Reply With Quote
windows 7,
and I've run everything from minimal linux distros through windows '95 and macOS. You simply wont get that same level of capatibility with anything else.
Craig
posted on 16/3/11 at 08:05 PM Reply With Quote
Mint 10 the Gnome version.
Although the KDE version of Mint is more like Windows and also easier to customise hence it also easier to break
montythemole
posted on 16/3/11 at 08:19 PM Reply With Quote
Another vote for ubuntu have it on laptops and desktop very windows like.
1985 Dutton Phaeton Series 3 1300GT
MikeFellows
posted on 16/3/11 at 10:49 PM Reply With Quote
i think you mean unix
ChrisL
posted on 16/3/11 at 10:57 PM Reply With Quote
Mike you're getting picky! OK so BSD is Unix not Linux, lol
MikeFellows
posted on 16/3/11 at 11:36 PM Reply With Quote
your ok,I didnt want to confuse anyone
(to be honest i probably made it worse and confused some poor souls about unix/linux)
ashg
posted on 16/3/11 at 11:56 PM Reply With Quote
i run ubuntu. cant fault it one bit and with wine installed you can run all your windows programs as well so best of both worlds
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
mad4x4
posted on 17/3/11 at 03:47 AM Reply With Quote
Have both Ubuntu & mint laptops at home - MINT is slow and crap and cluttered (and green) compared to ubuntu.
Use ubuntu on my works laptop even though we are a "windows" company. Run VMware to do software developemtn under windows.
I'm the only one that doesn;t get pestered with virus's (or is it viriiiiii???)
Supports everything except my kodak printer - even my HTC phone. WIfi everything straight out the box... multiple usb ethernet cards ... the works
Printing is the only problem check compatibility of your printer before making the jump to linux
[Edited on 17/303/11 by mad4x4]
posted on 17/3/11 at 07:24 AM Reply With Quote
If you find Mint slow something went very wrong with your install sometimes when Linux is installed if for example the wrong soundcard hardware is not correctly identified then programs will often slow to a crawl. --- Mint is Ubuntu but with the unrequired bits stripped out tailored for the desktop and the eyecandy is gorgeous a 1000 times better than Ubuntus awful brown.
As for running windows programmes I 100% agree that running in a virtual machine is the way to go, after a bit of testing I found Sun/Oracle VirtualBox (nb not the community supported version) was the best for me as it has proper USB support and runs every car diagnostic interface program I have ever tried on it.
[Edited on 17/3/11 by britishtrident]
posted on 17/3/11 at 08:35 AM Reply With Quote
Wine runs a lot of Windows programs but last time I looked it didn't run MS Access and runs into trouble with car diagnostic interface programs.
For any windows program that are more demanding and won't work under Wine running Windows in a virtual machine is the way to go. My favouriteOracle/Sun VirtualBox will run a windows virtual machine that has no problem with car diagnostic programs that use the usb ports.
ashg
posted on 17/3/11 at 08:58 AM Reply With Quote
must agree wine wont run everything. also must fess up i do have an xp vm running on sun/oracle virtual box or what ever they want to call it now for apps that wont run using wine.
[Edited on 17/3/2011 by ashg]
posted on 17/3/11 at 09:06 AM Reply With Quote
How much does the commercial version of VirtualBox cost?
posted on 17/3/11 at 10:46 AM Reply With Quote
Free for personal use :-)
http://www.oracle.com/technetwork/server-storage/virtualbox/downloads/index.html
posted on 17/3/11 at 03:38 PM Reply With Quote
Any idea which version of Ubuntu forms the basis of Linux Mint 10 (Julia)? I couldn't find it on the main Mint website.
Just so I can download the correct version of VirtualBox! :-)
posted on 17/3/11 at 05:10 PM Reply With Quote
Julia is "Maverick Meerkat" (Ubuntu 10.10 ) under the skin ---- that took a bit of finding.
posted on 17/3/11 at 05:25 PM Reply With Quote
Well done that man!
posted on 17/3/11 at 10:49 PM Reply With Quote
Oooh - I like VirtualBox!
I've just installed Windoze XP and it's working very well (it's the only legitimate install disk I've got - it was the installation that was on my machine before replacing with Mint).
Still not quite there yet, as I have tons of updates to catch up on... but I'll sort those in the morning (currently on "10 of 41" and I want to go to bed! )
snoopy
posted on 23/3/11 at 07:31 AM Reply With Quote
i am running linux mint 7 on my laptop .it was installed when linux mint7 came out about 3 years ago. and unlike windows it hasent broken itself yet not even a glitch
and it does everything a windows pc does the software is free and it downloads and installs itself having been using it for so long now i wouldnt change back
[Edited on 23/3/11 by snoopy]
