New Topic New Reply
Author: Subject: Post IVA Mods
40inches
posted on 9/10/13 at 09:10 AM Reply With Quote
Post IVA Mods
Part 1: The Steering Wheel
Needed to get rid of the yucky MGTF wheel
Was using Jaguar flappy paddles for the Klicktronic, so needed to make a mounting bracket.
The MGTF column uses a ribbon cable for the wheel electrics, so no dangling cables
A spacer ring moves the wheel from the paddles.
Better
Best
Just need to shorten the stalk.
daveb666
posted on 9/10/13 at 09:16 AM Reply With Quote
top work! That old wheel looked silly!
40inches
posted on 9/10/13 at 09:19 AM Reply With Quote
But IVA friendly
40inches
posted on 9/10/13 at 10:16 AM Reply With Quote
Part 2: The De-Cat
The exhaust was getting a little noisy, I found this:
The Truflex section had split after only 150 miles So I decided to rebuild the system without the Cat.
I had a straight through bike silencer lying around, so I modified the outlet and repacked with Acoustifil.
Fitted the exhaust using a larger Truflex section, this one has lasted 1500 miles, and still ok.
Nicer to drive now, no more ear bleeds and should be ok for track day noise levels.
Dynoed at 135bhp with this set up, happy with that.
Dick Axtell
posted on 9/10/13 at 04:37 PM Reply With Quote
Originally posted by 40inches
Part 2: The De-Cat
The Truflex section had split after only 150 miles.
Flexi-bellows piping - wasn't this a critical failure point in the Flixborough chemical plant "eruption"? Seem to recall that the subsequent inquiry raised criticism for using this type of connecting pipework, when it has to carry pressure pulses.
New Topic New Reply
