Author: Subject: Quaiffe Reversing Box, makes hell of a racket in reverse
philfingers
posted on 24/6/14 at 11:51 PM Reply With Quote
R1 Phoenix
never even been in a BEC before buying this one. There's a lot of drive train shunt. generally it's quiet moving forwards but in reverse the box makes a hell of racket, like a tin of ball bearings!
From what I've read it's installed correctly, the selector arm is at the back and reverse switch on the near side of the car.
I aslo read about all the issues with them. Doesn't appear to have leaked any oil, bottom of the tunnel is panelled in. So is this a common thing to be noisy in reverse but forward being better?
looking at probably changing the bearings shortly. The rear prop feels slightly loose
The true home of cars born under the Sylva name - http://jpsc.org.uk/forum
STM Phoenix R1
Sold-Sylva Striker 1300xf, 40s etc
Sold-Sylva Phoenix, 1300xf, BVH, 234cam, 2xDCOE 40s, live axle - 'old school', rally car and a few bikes
corrado vr6
posted on 25/6/14 at 10:57 AM Reply With Quote
Yep it's normal, it's the straight cut gears that makes it noises I believe
Mines not bad to be honest but I hardly have to use reverse which is good
http://r1indy7.wordpress.com/
philfingers
posted on 25/6/14 at 01:48 PM Reply With Quote
this isn't a straight cut gear noise, it's a f*cked noise i'm sure!
STM Phoenix R1
corrado vr6
posted on 25/6/14 at 04:12 PM Reply With Quote
Maybe upload a video of the noise, mines kinda grumbles as I use it in reverse
Have you checked the oil level?
philfingers
posted on 25/6/14 at 04:18 PM Reply With Quote
mmm, could do. Haven't checked oil levels as the builder didn't have the forethought to place an opening to view the plug. It doesn't leak, rather there's no evidence of any leaks, it's a flat bottomed/sealed tunnel car. If there was a leak would be obvious.
STM Phoenix R1
amalyos
posted on 25/6/14 at 04:48 PM Reply With Quote
Perhaps it doesn't leak because there's no oil in it, hence the noise..
http://stevembuild.blogspot.com
philfingers
posted on 5/7/14 at 09:30 PM Reply With Quote
your right, I doubt that there was ever any oil in it. I finally got it out today and there's about a serving spoon of oil in the bottom!
So next job is to strip it down and see what I find
STM Phoenix R1
